Prijs /prestatie vergelijking Subs + amps
(23 reacties. Pagina 1 van 3)Moderator(s): Dré
SuperkeesStandaard Lid Uit: Nederland Sinds: 30-5-2004 Laatste: 18-3-2014 Berichten: 30 | 13-4-2005 17:21 |
Hall beste mensen, Ik beschik al over 2 stuks Peavey UL15 tops en wil daar nu 4 stuks fatsoenlijke subs bij kopen met 2 versterkers. Qua subs twijfel ik tussen: - Omnitronic AX-1800 Rated power: 500 W RMS Program power: 1000 W Bass: 1x 18" Connections: 2 Speaker-sockets Sensitivity (1 W/m): 103 dB Max. SPL (1 m): 127 dB Impedance: 8 Ohms Frequency range: 35 Hz - 350 Hz Dimensions (H x W x D): 780 x 570 x 570 mm Weight: 69 kg Plaatje: www.omnitronic.com/jpg/artikel/001/11038960b.jpg Wat je niet ziet is dat de handgrepen (2 stuks) van die 4-kanten gaten zijn, wel degelijk dus Prijs: 299,- euro per stuk - Peavey UL118s 800 Watts RMS continuous, 1600 Watts program, 3200 Watts peak 8 Ohms 18'' (457mm) Low Rider™ sub woofer, cast frame with field-replaceable basket Frequency response: 38 Hz - 1 kHz Efficiency: 97dB Neutrik® Speakon® connectors Bi-amp operation only Resilient carpet covered Silver steel grille Satellite pole mounting 4 teardrop handles Lightweight Poplar Plywood construction Low turbulence venting system Made in the UK Dimensions: 30.1'' (765mm)H x 22.4'' (570mm)W x 26.4'' (670mm)D Weight: 78.2lbs (35.5kg) Plaatje: www.peavey-eu.com/images/products/messenger/15009170.jpg Prijs: 550,- euro per stuk Qua versterkers twijfel ik tussen: - Phonic XP3100 Advanced powerful performance 3rd generation circuitry design Output power: 1000W @ 4 ohms, 1400W @ 2 ohms Front mounted two low pass filters and two gain controls High continuous current output from robust toroidal transformer Switchable input peak limiter and selectable high pass filter (30Hz, 50Hz) to reduce distortion and protect speakers Bridge mono and parallel mode LEDs Fast Recovery design for lower distortion if clipping occurs Very rugged housing Active balanced inputs for low noise Signal level at -40, -20, -10, protect and clip LED indicators to monitor performance Ground Lift switch to prevent humming Selectable stereo, parallel & bridge mono amp modes Two ventilation variable speed fans Speakon®-type connectors and 5-way binding posts speaker outputs XLR & 1/4" TRS connectors for maximum input flexibility Requires three standard rack units for mounting Fits a standard 19" rack Prijs: 899,- euro per stuk Plaatje: www.phonic.com/images/products/xp3100.jpg Yamaha P-7000 Die neuen Power-Amps der P-Serie verfügen über solide Leistungsmerkmale in absolut professioneller Audioqualität für ein weitreichendes Anwendungsspektrum und so gut wie jede Anforderung. Die neue P-Serie erscheint in einem neuen, edlen wie eindrucksvollen Outfit mit tiefblauer Frontplatte, eingefasst in einen soliden, matt-silbergrauen Rahmen mit stabilen Griffen und Halterungen für den Rackeinbau. Bei der Fertigung des Chassis wurde besonders viel Wert auf Festigkeit und Beständigkeit gelegt, um auch dem rauesten Bühnenalltag zu trotzen. Die Lüfter, die sich hinter den Schlitzen links und rechts an der Frontplatte verbergen, kühlen effizient, zuverlässig und leise. Umfassende Schutzeinrichtungen wie das "Power-On/Off-Muting", die "DC-Detection", die "Thermal Protection", schnell ansprechendes Limiting und Überzüge für die Attenuatoren bewahren sowohl Ihre Poweramps als auch Ihre Boxen vor Schäden. Werfen Sie dich einmal einen Blick auf die technischen Daten der Poweramp-Serie. Sie werden feststellen, dass vor allem die Modelle P2500S und P3500S trotz aller Robustheit sehr leicht sind. Und selbst die beiden großen Amps, der P5000S und der P7000S, sind nicht wirklich Schwergewichte, bedenkt man dabei, wie viel sie leisten. Technische Daten P-7000: - 2x 750Watt / 8Ohm [ 1kHz / THD+N 1% ] - 2x 1100Watt / 4Ohm [ 1kHz / THD+N 1% ] - 1x 2000Watt / 8Ohm [ 1kHz / THD+N 1% ] Bridge - 2x 700Watt / 8Ohm [ 20-20kHz / THD+N 0,1% ] - 2x 950Watt / 4Ohm [ 20-20kHz / THD+N 0,1% ] - 1x 1900Watt / 8Ohm [ 20-20kHz / THD+N 0,1% ] Bridge - 2x 1600Watt / 2Ohm [ 1kHz / 20ms NonClip ] - 1x 3200Watt / 4Ohm [ 1kHz / 20ms NonClip ] Bridge - Frequenzbereich: 20Hz - 20kHz - Dämpfungsfaktor: >350 [ RL=8Ohm / 1kHz ] - Rauschspannungsabstand: 104dB [ S/N Ratio DIN ] - Intermodulare Verzerrung: <0,1% [ 60Hz-7kHz / 4:1 Halbe Leistung ] - max. Voltage Gain: 32,1dB - eingebaute Subwoofer Weiche - stufenlose Regelung der Trennfrequenz [ 25Hz-150Hz ] - schaltbare Einstellung [ LowCut / Subwoofer / Off ] - YAMAHA Speaker Processor zuschaltbar - Eingänge: sym. XLR / Klinke - Ausgänge: Speakon / Klinke / Schraubklemme - Status LED's [ Power / Protect / Temp / Process / Signal / Clip ] - Abmessung: 480x88x456 mm [ 19" / 2HE ] - Gewicht: 12Kg Prijs: 689,- euro per stuk Let eens op de maten en het gewicht! Graag hoor ik jullie keuzes, motieven en ervaringen over deze spullen. Alvast bedankt! | |
BartsegersStandaard Lid Uit: Nederland Sinds: 18-1-2002 Laatste: 28-10-2014 Berichten: 1463 | 13-4-2005 17:38 |
los van het feit dat ik niet alle specs langs elkaar leg. zou ik al neigen naar de ul serie, omdat je je tops al hebt ervan. beetje eenheid kan geen kwaad. | |
SuperkeesStandaard Lid Uit: Nederland Sinds: 30-5-2004 Laatste: 18-3-2014 Berichten: 30 | 13-4-2005 18:26 |
Daar zit wat in Maargoed als je dan die prijzen bekijkt, ik bedoel als het dan op het zelfde neerkomt zou het toch zonde zijn heh Ik vraag me af of omnitronic eigenlijk wel te vergelijken is met peavey? Ik zag wel dat die omnitronic subs ook rond de 500 euro kosten bij gemiddelde bedrijven.. | |
RutgerStandaard Lid Uit: Nederland Sinds: 12-9-2003 Laatste: 24-1-2018 Berichten: 196 | 13-4-2005 18:30 |
zou toch echt voor de peavy gaan, staat ook nog beter sub top van het zelfde merk. | |
Arjan schuurmanStandaard Lid Uit: Nederland Sinds: 26-1-2004 Laatste: 10-4-2024 Berichten: 106 | 13-4-2005 19:41 |
RCF esw 1018 niks voor je?heb nog een leuke set te koop zie tweedehands forum.groeten Arjan | |
SuperkeesStandaard Lid Uit: Nederland Sinds: 30-5-2004 Laatste: 18-3-2014 Berichten: 30 | 13-4-2005 19:59 |
zou toch echt voor de peavy gaan, staat ook nog beter sub top van het zelfde merk. De vraag is alleen of ik daar 600 euro voor over heb. En dàt hangt weer af van de verschillen tussen beide subs heh. Dat is dus waar ik benieuwd naar ben, wat denken jullie?Bedankt voor je aanbod arjan, zit er mooi uit Maar voor die paar honderd euro koop ik liever èchte peaveys dan (Het scheelt maar 160 euro per sub ) Edit: Hey arjan nog een vraagje aan je dan; wat voor zalen draaide je ongeveer met 4 van die subs en 2 tops? dan kan ik ongeveer van het zelfde uitgaan. | |
PowerbeatStandaard Lid Uit: Nederland Sinds: 4-1-2005 Laatste: 10-9-2014 Berichten: 808 | 13-4-2005 21:17 |
Denk alleen dat het krap zat is 4 subs ul118S en 2 ul-15's ik heb zelf die 2 subs en die 2 tops en ben zeer tevreden. Subs presteren zeer zeer goed. Niets dan lof. Als je het kan doen zou ik zeggen 4x ul118S maar dan krijg je het punt-> Ik denk niet dat je top dat red? het is gewoon te weinig echt hoog denk ik. De slimste optie voor dit probleem komt echter niet meer van mij ben ik bang. En over de amps. Kijk eens naar 2x American Audio V4000 om ze in brug te zetten. Hoor niets dan lof over. (zelf 1x Pv2600 in brug die ik toch wel iets lager inschat. tot nu toe echter goed resultaat. En heb nog geen beperking van deze amp gevonden dus evt. ook nog het bekijken waard?) | |
I'll take you to the KoffieShop... | |
RademakersVIP Lid Uit: Nederland Sinds: 28-7-2003 Laatste: 21-11-2024 Berichten: 1345 | 14-4-2005 11:45 |
De specs van die Omnitronic zijn niet alleen gelogen, ze zijn ook samengesteld door iemand die geen verstand van luidsprekers heeft (verhoudingen kloppen niet). En waarom wegen ze in hemelsnaam 69 kg? Persoonlijk zou ik neigen naar zelfbouw maar anders de Peavey's. Mvg Johan | |
1-2-3-4-hoedje-van... | |
Boyz_PCStandaard Lid Uit: Nederland Sinds: 10-4-2004 Laatste: 9-9-2020 Berichten: 48 | 14-4-2005 12:45 |
- Omnitronic AX-1800 dit zijn gewoon RCF esw1018 kopieën, alleen wel slechte. - Peavey UL118s Goede kast die bij je tops past, 1 sub per top is genoeg Beide versterkers zijn goed maar niet geschikt voor de Peavey subs dan moet je echt een slag zwaarder gaan of per sub een gebrugde versterker nemen. Maar kijk eens naar de Phonic XP5100. Ben zelf niet zo een voorstander van een buitl in x-over maar het is wel handig | |
PowerbeatStandaard Lid Uit: Nederland Sinds: 4-1-2005 Laatste: 10-9-2014 Berichten: 808 | 14-4-2005 15:09 |
2 gebrugde amps zijn vaak goedkoper, flexibeler, en waardevaster als 1 megabak. 2xPV1500 is wel iets vermogentekort maar naar mijn mening wel genoeg om je 2 tops ten volle te benutten(bedoel dus dat je anders te veel bas, als dat kan, zou krijgen) wil je de verhoudingen een beetje recht houden. en 1000 watt op 8 ohm vind je niet gauw in een stereo bak. | |
