Prijs /prestatie vergelijking Subs + amps
(23 reacties. Pagina 1 van 3)
SuperkeesStandaard Lid
Sinds: 30-5-2004
Laatste: 18-3-2014
13-4-2005 17:21
Hall beste mensen,
Ik beschik al over 2 stuks Peavey UL15 tops en wil daar nu 4 stuks fatsoenlijke subs bij kopen met 2 versterkers.
Qua subs twijfel ik tussen:
- Omnitronic AX-1800
Rated power: 500 W RMS
Program power: 1000 W
Bass: 1x 18"
Connections: 2 Speaker-sockets
Sensitivity (1 W/m): 103 dB
Max. SPL (1 m): 127 dB
Impedance: 8 Ohms
Frequency range: 35 Hz - 350 Hz
Dimensions (H x W x D): 780 x 570 x 570 mm
Weight: 69 kg
Plaatje: www.omnitronic.com/jpg/artikel/001/11038960b.jpg
Wat je niet ziet is dat de handgrepen (2 stuks) van die 4-kanten gaten zijn, wel degelijk dus
Prijs: 299,- euro per stuk
- Peavey UL118s
800 Watts RMS continuous, 1600 Watts program, 3200 Watts peak
8 Ohms
18'' (457mm) Low Rider™ sub woofer, cast frame with field-replaceable basket
Frequency response: 38 Hz - 1 kHz
Efficiency: 97dB
Neutrik® Speakon® connectors
Bi-amp operation only
Resilient carpet covered
Silver steel grille
Satellite pole mounting
4 teardrop handles
Lightweight Poplar Plywood construction
Low turbulence venting system
Made in the UK
Dimensions: 30.1'' (765mm)H x 22.4'' (570mm)W x 26.4'' (670mm)D
Weight: 78.2lbs (35.5kg)
Plaatje: www.peavey-eu.com/images/products/messenger/15009170.jpg
Prijs: 550,- euro per stuk
Qua versterkers twijfel ik tussen:
- Phonic XP3100
Advanced powerful performance 3rd generation circuitry design
Output power: 1000W @ 4 ohms, 1400W @ 2 ohms
Front mounted two low pass filters and two gain controls
High continuous current output from robust toroidal transformer
Switchable input peak limiter and selectable high pass filter (30Hz, 50Hz) to reduce distortion and protect speakers
Bridge mono and parallel mode LEDs
Fast Recovery design for lower distortion if clipping occurs
Very rugged housing
Active balanced inputs for low noise
Signal level at -40, -20, -10, protect and clip LED indicators to monitor performance
Ground Lift switch to prevent humming
Selectable stereo, parallel & bridge mono amp modes
Two ventilation variable speed fans
Speakon®-type connectors and 5-way binding posts speaker outputs
XLR & 1/4" TRS connectors for maximum input flexibility
Requires three standard rack units for mounting
Fits a standard 19" rack
Prijs: 899,- euro per stuk
Plaatje: www.phonic.com/images/products/xp3100.jpg
Yamaha P-7000
Die neuen Power-Amps der P-Serie verfügen über solide Leistungsmerkmale in absolut professioneller Audioqualität für ein weitreichendes Anwendungsspektrum und so gut wie jede Anforderung. Die neue P-Serie erscheint in einem neuen, edlen wie eindrucksvollen Outfit mit tiefblauer Frontplatte, eingefasst in einen soliden, matt-silbergrauen Rahmen mit stabilen Griffen und Halterungen für den Rackeinbau. Bei der Fertigung des Chassis wurde besonders viel Wert auf Festigkeit und Beständigkeit gelegt, um auch dem rauesten Bühnenalltag zu trotzen. Die Lüfter, die sich hinter den Schlitzen links und rechts an der Frontplatte verbergen, kühlen effizient, zuverlässig und leise. Umfassende Schutzeinrichtungen wie das "Power-On/Off-Muting", die "DC-Detection", die "Thermal Protection", schnell ansprechendes Limiting und Überzüge für die Attenuatoren bewahren sowohl Ihre Poweramps als auch Ihre Boxen vor Schäden.
Werfen Sie dich einmal einen Blick auf die technischen Daten der Poweramp-Serie. Sie werden feststellen, dass vor allem die Modelle P2500S und P3500S trotz aller Robustheit sehr leicht sind. Und selbst die beiden großen Amps, der P5000S und der P7000S, sind nicht wirklich Schwergewichte, bedenkt man dabei, wie viel sie leisten.
Technische Daten P-7000:
- 2x 750Watt / 8Ohm [ 1kHz / THD+N 1% ]
- 2x 1100Watt / 4Ohm [ 1kHz / THD+N 1% ]
- 1x 2000Watt / 8Ohm [ 1kHz / THD+N 1% ] Bridge
- 2x 700Watt / 8Ohm [ 20-20kHz / THD+N 0,1% ]
- 2x 950Watt / 4Ohm [ 20-20kHz / THD+N 0,1% ]
- 1x 1900Watt / 8Ohm [ 20-20kHz / THD+N 0,1% ] Bridge
- 2x 1600Watt / 2Ohm [ 1kHz / 20ms NonClip ]
- 1x 3200Watt / 4Ohm [ 1kHz / 20ms NonClip ] Bridge
- Frequenzbereich: 20Hz - 20kHz
- Dämpfungsfaktor: >350 [ RL=8Ohm / 1kHz ]
- Rauschspannungsabstand: 104dB [ S/N Ratio DIN ]
- Intermodulare Verzerrung: <0,1% [ 60Hz-7kHz / 4:1 Halbe Leistung ]
- max. Voltage Gain: 32,1dB
- eingebaute Subwoofer Weiche
- stufenlose Regelung der Trennfrequenz [ 25Hz-150Hz ]
- schaltbare Einstellung [ LowCut / Subwoofer / Off ]
- YAMAHA Speaker Processor zuschaltbar
- Eingänge: sym. XLR / Klinke
- Ausgänge: Speakon / Klinke / Schraubklemme
- Status LED's [ Power / Protect / Temp / Process / Signal / Clip ]
- Abmessung: 480x88x456 mm [ 19" / 2HE ]
- Gewicht: 12Kg
Prijs: 689,- euro per stuk
Let eens op de maten en het gewicht! happy :)
Graag hoor ik jullie keuzes, motieven en ervaringen over deze spullen.
Alvast bedankt! happy :)
BartsegersStandaard Lid
Sinds: 18-1-2002
Laatste: 28-10-2014
13-4-2005 17:38
los van het feit dat ik niet alle specs langs elkaar leg. zou ik al neigen naar de ul serie, omdat je je tops al hebt ervan. beetje eenheid kan geen kwaad.
Sinds: 30-5-2004
Laatste: 18-3-2014
13-4-2005 18:26
Daar zit wat in wink ;) Maargoed als je dan die prijzen bekijkt, ik bedoel als het dan op het zelfde neerkomt zou het toch zonde zijn heh happy :) Ik vraag me af of omnitronic eigenlijk wel te vergelijken is met peavey? Ik zag wel dat die omnitronic subs ook rond de 500 euro kosten bij gemiddelde bedrijven..
RutgerStandaard Lid
Sinds: 12-9-2003
Laatste: 24-1-2018
13-4-2005 18:30
zou toch echt voor de peavy gaan, staat ook nog beter sub top van het zelfde merk.
Arjan schuurmanStandaard Lid
Sinds: 26-1-2004
Laatste: 10-4-2024
13-4-2005 19:41
RCF esw 1018 niks voor je?heb nog een leuke set te koop zie tweedehands forum.groeten Arjan
Sinds: 30-5-2004
Laatste: 18-3-2014
13-4-2005 19:59
De vraag is alleen of ik daar 600 euro voor over heb. En dàt hangt weer af van de verschillen tussen beide subs heh. Dat is dus waar ik benieuwd naar ben, wat denken jullie?
Bedankt voor je aanbod arjan, zit er mooi uit happy :)
Maar voor die paar honderd euro koop ik liever èchte peaveys dan happy :) (Het scheelt maar 160 euro per sub shocked 8O )
Edit: Hey arjan nog een vraagje aan je dan; wat voor zalen draaide je ongeveer met 4 van die subs en 2 tops? dan kan ik ongeveer van het zelfde uitgaan.
PowerbeatStandaard Lid
Sinds: 4-1-2005
Laatste: 10-9-2014
13-4-2005 21:17
Denk alleen dat het krap zat is 4 subs ul118S en 2 ul-15's ik heb zelf die 2 subs en die 2 tops en ben zeer tevreden. Subs presteren zeer zeer goed. Niets dan lof. Als je het kan doen zou ik zeggen 4x ul118S maar dan krijg je het punt-> Ik denk niet dat je top dat red? het is gewoon te weinig echt hoog denk ik. De slimste optie voor dit probleem komt echter niet meer van mij ben ik bang. En over de amps. Kijk eens naar 2x American Audio V4000 om ze in brug te zetten. Hoor niets dan lof over. (zelf 1x Pv2600 in brug die ik toch wel iets lager inschat. tot nu toe echter goed resultaat. En heb nog geen beperking van deze amp gevonden dus evt. ook nog het bekijken waard?)
RademakersVIP Lid
Sinds: 28-7-2003
Laatste: 3-7-2024
14-4-2005 11:45
De specs van die Omnitronic zijn niet alleen gelogen, ze zijn ook samengesteld door iemand die geen verstand van luidsprekers heeft (verhoudingen kloppen niet). En waarom wegen ze in hemelsnaam 69 kg?
Persoonlijk zou ik neigen naar zelfbouw maar anders de Peavey's.
Mvg Johan
1-2-3-4-hoedje-van...
Boyz_PCStandaard Lid
Sinds: 10-4-2004
Laatste: 9-9-2020
14-4-2005 12:45
dit zijn gewoon RCF esw1018 kopieën, alleen wel slechte.
- Peavey UL118s
Goede kast die bij je tops past, 1 sub per top is genoeg
Beide versterkers zijn goed maar niet geschikt voor de Peavey subs dan moet je echt een slag zwaarder gaan of per sub een gebrugde versterker nemen. Maar kijk eens naar de Phonic XP5100.
Ben zelf niet zo een voorstander van een buitl in x-over maar het is wel handig
Sinds: 4-1-2005
Laatste: 10-9-2014
14-4-2005 15:09
2 gebrugde amps zijn vaak goedkoper, flexibeler, en waardevaster als 1 megabak. 2xPV1500 is wel iets vermogentekort maar naar mijn mening wel genoeg om je 2 tops ten volle te benutten(bedoel dus dat je anders te veel bas, als dat kan, zou krijgen) wil je de verhoudingen een beetje recht houden. en 1000 watt op 8 ohm vind je niet gauw in een stereo bak.
