MicW i436 Calibrated Measurement Mini Microphone for iPad, iPhone e.d.
(63 reacties. Pagina 5 van 7)Moderator(s): Dré
DanielVIP Lid Uit: Nederland Sinds: 9-3-2004 Laatste: 15-5-2025 Berichten: 384 | 14-3-2015 08:51 |
Die dip zit precies waar het oor het meest gevoelig is. Wellicht wordt dit bewust zo gedaan. en.wikipedia.org/wiki/Equal-loudness_contour | |
AudiopartnerStandaard Lid Uit: Nederland Sinds: 24-6-2009 Laatste: 7-5-2025 Berichten: 116 | 14-3-2015 21:25 |
Dave Rat heeft nogal uitputtende tests aan hoofdtelefoons gedaan, een aantal jaren terug heb ik ze voorbij zien komen, de meetmethode was vergelijkbaar. Moet nog wel te vinden zijn. | |
Trainingen, STIPA/SPL meetsystemen van NTi-Audio en Bedrock-Audio . Offerte service geluidsplan met EASE jr. | |
WebbieStandaard Lid Uit: Nederland Sinds: 27-12-2002 Laatste: 10-2-2025 Berichten: 2129 | 14-3-2015 21:49 |
Hallo Daniel, Daniel schreef: Die dip zit precies waar het oor het meest gevoelig is. Wellicht wordt dit bewust zo gedaan.en.wikipedia.org/wiki/Equal-loudness_contour Good headphones, well sealed to the ear, can provide a very flat low-frequency pressure response measured at the ear canal, with low distortion even at high intensities, and at low frequencies the ear is purely pressure-sensitive, and the cavity formed between headphones and ear is too small to introduce any modifying resonances. Headphone testing is therefore a good way to derive equal-loudness contours below about 500 Hz, although reservations have been expressed about the validity of headphone measurements when determining the actual threshold of hearing, based on observation that closing off the ear canal produces increased sensitivity to the sound of blood flow within the ear which appears to be masked by the brain in normal listening conditions. It is at high frequencies that headphone measurement gets unreliable, and the various resonances of pinnae (outer ear) and ear canal are severely affected by proximity to the headphone cavity. Het eerste wat ik heb gedaan is een velcro kabelbinder om de test bank en oorschelp gedaan om hem wat lichtjes aan te drukken......... Tweede wat ik gedaan heb, en ook logisch is na het lezen van de eerder ge-quote tekst, de microfoon dieper het schuim ingedrukt. Steeds tussendoor een spectrum meting gedaan om te kijken of de 4k dip minder werd als ik ook de microfoon dieper in het schuim duwde. En ja hoor de dip werd minder, op 15mm diepte was de dip het minst (9dB verschil met de eerste metingen ![]() Nog wat kijkvoer: Spectrum meting van de BeyerDynamic DT770 Pro (80 Ohm). Legenda: Rood = oude meting met de microfoon gelijk met het schuim. Groen = nieuwe meting met de microfoon 15mm diep het schuim in. ![]() Transfer meting van de BeyerDynamic DT770 Pro (80 Ohm). Om een goede microfoon test bank te maken moet er naar mijn idee nog het volgende gebeuren:Legenda: Rood = oude meting met de microfoon gelijk met het schuim. Roze = nieuwe meting met de microfoon 15mm diep het schuim in. ![]()
These go to Eleven ... | |
WebbieStandaard Lid Uit: Nederland Sinds: 27-12-2002 Laatste: 10-2-2025 Berichten: 2129 | 2-6-2015 12:52 |
Hallo, Ik heb de MicW i436 dus nu een tijdje gehad, maar door het niet accuraat (genoeg) meten van de microfoon hem weer verkocht. Ik heb de i436 gebruikt zowel met de iPad (i.c.m. Smaart Tools, in-app aankoop voor AudioTools van Studio Six Digital) als mijn MacBook Pro (Smaart v7 Di). Uit mijn metingen valt op te maken dat de MicW i436 al af valt bij de 9 kHz (als referentie genomen de Neutrik 3382) en de geluidsdruk blijft achter totdat je de gekalibreerde waarde (in mijn geval 94 dB) bereikt. De verschillen in geluidsdruk van de i436 t.o.v. twee andere microfoons (Neutrik 3382 en iSEMic 725TR) bedraagt zo'n 0,5 dB - 0,6 dB. Eigenlijk is het niet meer als een leuk hebbedingetje, wil je metingen gaan doen waar je wat meer aan hebt (en zowel op je mobile device, laptop of PC die wil gaan uitvoeren) zul je 100,- Euro extra moeten gaan uitgeven aan de iSEMic 725TR. ![]() ![]() Op mijn weblog heb ik inmiddels het een en ander neergezet met de eerste metingen en hoe te gebruiken met Smaart. www.blouder.com/using-micw-i436-with-smaart-v7-... Binnenkort komt het article online met nieuwe metingen (Timo Beckman heeft mij nuttige tips gegeven om microfoons te vergelijken, die ik dan voor de eerste keer toepas) tussen de eerder genoemde meetmicrofoons, namelijk: de MicW i436, iSEMic 725TR en Neutrik 3382. (trouwens een pluim voor de importeur hier in Nederland van MicW, Fred van Eijk, die heel behulpzaam was naar het zoeken van oplossingen) Greetz Webbie... | |
JadjongStandaard Lid Uit: Nederland Sinds: 6-8-2002 Laatste: 2-1-2021 Berichten: 614 | 2-6-2015 13:49 |
Ik heb nog een Superlux 999 in de aanbieding, die is nog eens vier euro goedkoper dan de bekende Behringer en zwart! ![]() Interesse om die ook te testen? | |
WebbieStandaard Lid Uit: Nederland Sinds: 27-12-2002 Laatste: 10-2-2025 Berichten: 2129 | 2-6-2015 18:49 |
Hallo Jadjong, jadjong schreef: Ik heb nog een Superlux 999 in de aanbieding, die is nog eens vier euro goedkoper dan de bekende Behringer en zwart!![]() Interesse om die ook te testen? Greetz Webbie... | |
WebbieStandaard Lid Uit: Nederland Sinds: 27-12-2002 Laatste: 10-2-2025 Berichten: 2129 | 17-3-2016 13:57 |
Hallo, Onderstaande meetmicrofoontje kwam ik tegen vandaag, de Dayton Audio iMM-6 Calibrated Measurement Micro..., geen idee of het wat is. Wel opmerkelijk dat het wordt geleverd met een voor elk exemplaar uniek calibratiebestand. En een stuk goedkoper als de MicW 1436 die hier eerder is besproken, die ook nog zonder calaibratiebestand wordt geleverd. De IMM-6 is voor 23,95 Euro in Nederland te koop. ![]() ![]() Greetz Webbie... | |
DréAdministrator Uit: Nederland Sinds: 17-11-2001 Laatste: 18-5-2025 Berichten: 13504 | 17-3-2016 16:01 |
Jammer dat er op de productpagina zelf niet een gemiddelde curve te vinden is. Ook hier is het afwachten of de calibratiegegevens echt van de microfoon zelf zijn en niet een soort van gimmick. Gezien de prijs is het wellicht een gokje waard. Koptelefoonaansluiting had van mij wel haaks mogen staan of wellicht zelfs met een draadje in plaats van massief (komt nu erg dicht bij het kapsel terecht). | |
WebbieStandaard Lid Uit: Nederland Sinds: 27-12-2002 Laatste: 10-2-2025 Berichten: 2129 | 17-3-2016 17:24 |
1 x bewerkt. Laatst door Webbie op 17-3-2016 18:13 Hallo Dré,Dré schreef: Jammer dat er op de productpagina zelf niet een gemiddelde curve te vinden is. Ook hier is het afwachten of de calibratiegegevens echt van de microfoon zelf zijn en niet een soort van gimmick. Gezien de prijs is het wellicht een gokje waard.Koptelefoonaansluiting had van mij wel haaks mogen staan of wellicht zelfs met een draadje in plaats van massief (komt nu erg dicht bij het kapsel terecht). Persoonlijk vind ik het altijd een beetje "eng" om zo'n uitsteeksel rechtstreeks op de hoofdtelefoonaansluiting te zetten van mobieltje/tablet.Er hoeft meer iets of iemand tegen aan te stoten en hoofdtelefoonaansluiting e/of je microfoon is om zeep. Beter dan om er inderdaad verlengkabeltje tussen te doen. Vooral als ze zo'n "lange" hebt als ik ![]() (ik doel natuurlijk op de iSEMic 725TR hieronder op de foto's) ![]() ![]() ![]() ![]() TIP: de K&M iPad houders waarvan je er een op de laatste foto ziet zijn ideale dingen om op een (mini) statief te zetten. Dit geeft bij het meten en/of foto's/films te maken veel meer stabiliteit. Ik gebruik zelfs ook zo'n houder voor in de auto (Fiat Fiorino 2008) voor mijn iPad mini. ![]() Greetz Webbie... | |
HollenderVIP Lid Uit: België Sinds: 20-2-2006 Laatste: 18-5-2025 Berichten: 1239 | 17-3-2016 18:06 |
Dré schreef: Jammer dat er op de productpagina zelf niet een gemiddelde curve te vinden is. Ook hier is het afwachten of de calibratiegegevens echt van de microfoon zelf zijn en niet een soort van gimmick. Gezien de prijs is het wellicht een gokje waard. Koptelefoonaansluiting had van mij wel haaks mogen staan of wellicht zelfs met een draadje in plaats van massief (komt nu erg dicht bij het kapsel terecht). | |
Free beats! |
