Zware scan!
(72 reacties. Pagina 7 van 8)Moderator(s): Dré
MR TStandaard Lid Uit: België Sinds: 4-6-2004 Laatste: 2-4-2018 Berichten: 64 | 25-12-2007 23:49 |
Eventjes een kleine scan gevonden. Technical Specification _________________________________________________________________________________________ ............................RazorHead7.............................RazorHead10 Dimensions................1956h 1290w 1375d.................2964h 1601w 1655d Weight......................240 kg..................................500 kg Power Supply................7 kw...................................10 kw Movement..............................360° x 360° continuous dual axis Speed....................................0.06 to 60rpm 0.06 to 40rpm Resolution...............................Movement 12 bit - Effects 16 bit Colour Option..........................Cyan Magenta and Yellow Dimmer Option.........................Radial shutter with smooth dimming 0-100% and strobe effect from 0.5-12Hz rate Optical Path................460mm diameter.........................715mm diameter Control...................................USITT DMX512 compatible Optional Effects.......................Four expansion slots for effects cards. (n.b. CMY colour card occupies 2 slots) Razorhead | |
don't forget --> The sky is the limit | |
DJ BartjeStandaard Lid Uit: Nederland Sinds: 14-6-2006 Laatste: 6-5-2025 Berichten: 569 | 26-12-2007 19:46 |
MR T schreef: Eventjes een kleine scan gevonden.Technical Specification _________________________________________________________________________________________ ............................RazorHead7.............................RazorHead10 Dimensions................1956h 1290w 1375d.................2964h 1601w 1655d Weight......................240 kg..................................500 kg Power Supply................7 kw...................................10 kw Movement..............................360° x 360° continuous dual axis Speed....................................0.06 to 60rpm 0.06 to 40rpm Resolution...............................Movement 12 bit - Effects 16 bit Colour Option..........................Cyan Magenta and Yellow Dimmer Option.........................Radial shutter with smooth dimming 0-100% and strobe effect from 0.5-12Hz rate Optical Path................460mm diameter.........................715mm diameter Control...................................USITT DMX512 compatible Optional Effects.......................Four expansion slots for effects cards. (n.b. CMY colour card occupies 2 slots) Razorhead of ben ik nu verkeerd aan het denken? ![]() | |
Joepjuh7Standaard Lid Uit: Nederland Sinds: 12-12-2003 Laatste: 28-4-2014 Berichten: 110 | 26-12-2007 19:58 |
Fout, bij een movinghead beweegt de lamp + kleurenschijven en dergelijke mee en word er geen gebruik gemaakt van spiegels. Bij een scanner staan de lamp + kleurenschijven e.d stil en word de lichstraal gericht doormiddel van spiegels. Anders zou de GLP Patent light ook een movinghead zijn, want deze draait ook 360 graden. | |
Sonic boomStandaard Lid Uit: Nederland Sinds: 12-11-2006 Laatste: 6-2-2010 Berichten: 221 | 26-12-2007 20:15 |
In de tekst op de gelinkte pagina staat dat het een searchlight is, ik neem dus aan dat dat het dan ook is, en geen scanner of moving head ![]() | |
T is warm werk maar zeker de moeite waard ;-) | |
ReemskiVIP Lid Uit: Nederland Sinds: 22-10-2002 Laatste: 14-5-2025 Berichten: 1370 | 27-12-2007 12:32 |
sonic boom schreef: In de tekst op de gelinkte pagina staat dat het een searchlight is, ik neem dus aan dat dat het dan ook is, en geen scanner of moving head![]() Dit is gewoon een massive scan. | |
DouweVIP Lid Uit: Nederland Sinds: 7-2-2002 Laatste: 2-5-2025 Berichten: 1139 | 2-1-2008 21:36 |
sonic boom schreef: In de tekst op de gelinkte pagina staat dat het een searchlight is, ik neem dus aan dat dat het dan ook is, en geen scanner of moving head![]() Ontzettend knap bedacht om een Xenon searchlight de snelheid van een scan te geven. Wat ik me afvraag is hoelang de spiegels de enorme IR en UV stralen zullen overleven. Er is niet voor niets een minimum afstand voor een Xenon bulb bedacht. | |
JHM LightingStandaard Lid Uit: Nederland Sinds: 11-1-2008 Laatste: 8-3-2008 Berichten: 1 | 7-3-2008 13:33 |
Wij produceren zelf dit soort lampen ( nu nog tot slechts 5 Kw) en we hebben er nu een stuk of 20 in Nederland op voorraad. Bij ons is het inderdaad ook meer een Outdoor movinghead, dan een gewoon zoeklicht. Kleuren mixing (CMY), Strobe functie, DMX aanstuurbaar etc. Als je ziet hoe soepel ze draaien ondanks het formaat...echt ongelooflijk. En een straal in de lucht met strobe functie.... ![]() https://www.skylights.nl/30/5/Onze%20Skylights/Nieuw%20!!/ | |
DeMennooosVIP Lid Uit: Nederland Sinds: 10-10-2002 Laatste: 14-10-2020 Berichten: 314 | 7-3-2008 13:55 |
Leuk, alleen erg jammer dat er op de Skylights website veel foto's voorbij komen waarop SpaceCannon spots zijn gebruikt en niet de JHM units... Vooral dit is wel een leuke... klik Bovenste foto is van de Olympische Spelen in Australie en is gedaan met SpaceCannon Ireos 4th. klik Onderste foto is Festa della città di Mosca Mosca - Russia - 2004 ook gedaan met SpaceCannon Ireos 4th. klik En dit is wel de meest bekende... Skylights link SpaceCannon Origineel Advies: Laat ze die foto's van de site halen. Die Italianen zijn niet al te flauw bij oneigenlijk gebruik van hun foto's... | |
JurrieStandaard Lid Uit: Nederland Sinds: 5-4-2003 Laatste: 4-1-2024 Berichten: 620 | 7-3-2008 14:58 |
En je maakt zelf de fixtures (ook die op je eigen site staan?)? Geloof er eigenlijk weinig van, ziet eruit als OEM china kopietjes... En anders petje af, aardig assortiment. | |
VictorVIP Lid Uit: Nederland Sinds: 23-8-2002 Laatste: 10-5-2025 Berichten: 5307 | 7-3-2008 18:43 |
DeMennooos schreef: Leuk, alleen erg jammer dat er op de Skylights website veel foto's voorbij komen waarop SpaceCannon spots zijn gebruikt en niet de JHM units... | |
