A&H komt eraan met een nieuw Xone model (mixer)
(148 reacties. Pagina 4 van 15)
MEStandaard Lid
Sinds: 3-1-2003
Laatste: 2-12-2009
11-12-2003 22:33
Whooooooooo ik zou iedereen aanraden dit te bekijken. Supper mooi ding. Wat mist er, helemaal niets. Volgens mij hebben we hier een DJM-600 beater (alsof dat zo moeilijk is wink ;) ). www.allen-heath.com/xone/92_front_elevation.jpg en supper mooi filmpje www.allen-heath.com/xone/movie17.html
Dré ga jij hem ook leveren en wanneer???
correct me if I'm wrong...
ClubbedtodeathStandaard Lid
Sinds: 3-9-2003
Laatste: 5-8-2005
12-12-2003 01:03
Ziet er een prachtige mixer uit.
Dit zijn de eigenschappen:
6 stereo channels (4 phono or line, 2 mono/mic or stereo return)
2 auxiliary sends selectable pre/post fader (and crossfader)
MIDI output from VCF 1+2, crossfader, LFO (MIDI clock), dedicated data control and start/stop button
New twin-rail VCA channel faders or high quality VCA rotary faders
2 independent stereo mix outputs
2 VCF filters - any performance channel can be assigned to either filter and either side of crossfader
2 x independent Low Frequency Oscillators (LFO) for filter modulation
Active crossfader allowing contour to be set from smooth to scratch mix
Custom illumination showing status of all performance switches
4 band EQ - high definition of frequency bands, with ‘infinite kill’ on HF and LF; wide Q for cut, narrow Q for boost.
Dedicated booth output
Metering - extensive channel, output and cue metering
Intelligent cue system allowing pre or post EQ monitoring
Monitor section - includes post EQ switch; split cue and mix to cue balance
2 x headphone outputs ¼” and 3.5mm jack
Talkover facility on mono/mic channel attenuates music by 20dB
Dedicated clean feed record output
Universal power supply for worldwide performance
Internal installer options for system optimisation
Plinth or 19” rack mount ears included
...Spare knobs included
…. and of course, the legendary A&H sound and build quality
Maar denon komt in januari ook met een nieuwe mixer:DN-X1500
Deze heeft ook effecten, sampler die je kan upgraden via de USB-poort aan de mixer
Zal eveneens een concurent zijn van pioneer!
SnakeEffect Guru
Sinds: 17-2-2003
Laatste: 19-4-2014
12-12-2003 08:08
Van het andere topic:
loinz schreef:
Erg gaaf, ze hebben eindelijk effect send en return erin gestopt, zeer handig.
Nope. Nog steeds geen effect loop voorhanden. Alleen hebben ze de line-ingang van de microfoonkanalen even de naam 'effect return' gegeven... Net hetzelfde als bij de Xone:62 dus met andere woorden.
Verder vind ik het spijtig dat ze er weer allerhande dure gadgets op gezet hebben; zelfs een midi-clock. Frontpaneel is ook wat druk vind ik. Nee, A&H heeft bij deze slechte punten gekregen wat mij betreft. Wat wel een voordeel is misschien, is dat deze wel de Pioneer effect mixers een beetje van de markt kan gaan duwen. En als de geluidskwaliteit van die aard is die we van A&H gewoon zijn is dat wel een goede zaak natuurlijk.
SaithnStandaard Lid
Sinds: 7-8-2003
Laatste: 27-6-2007
12-12-2003 15:13
vinden jullie die knobs ook zo dicht op elkaar zitten sad :(
Wel een mooi mixertje hoor, maar ik vraag me af of ik het prijsverschil wel over heb om deze te kopen ipv de 62
Wat zijn nou eigenlijk precies de verschillen?
SnakeEffect Guru
Sinds: 17-2-2003
Laatste: 19-4-2014
12-12-2003 18:25
www.allen-heath.com
www.xone.co.uk
Kun je gemakkelijk zelf vinden. Echt, walk in the park.
SnakeEffect Guru
Sinds: 17-2-2003
Laatste: 19-4-2014
22-12-2003 13:55
www.allen-heath.com/AHImages/92_launch/p031.jpg
Bestaat dus ook in rotary-versie -> stond wel op de Xone webstek maar geen foto te bespeuren ginds.
Op www.releaseyourself.com zei een kerel dat de :92 6000 dollars ging kosten. Geloof ik zelf niet maar geloof wél dat het een prijzig beestje gaat worden.
[offtopic]
www.allen-heath.com/AHImages/92_launch/p867.jpg
Bekertje op de CDJ-1000 -> veilig :)
[/offtopic]
Dj diëgoStandaard Lid
Sinds: 21-9-2003
Laatste: 3-2-2010
22-12-2003 15:46
The SRP is £999.95 and the mixer will be available from February
niet dus.
staat op de site zelf dus dat is ongeveer 1500 euro en dat is de adviesprijs dus verwacht maar iets van 1350 ofzo.
hahaha je hebt gelijk is me niet opgevallen, toen ik zat te kijken ik zat alleen te kwijlen aan de xone 92 maar hopelijk is het toch nog goed gegaan voor ze
Who ever said life is short it's the longest goddamn thing you do, are you gonna do something that's longer!
DimitriStandaard Lid
Sinds: 30-8-2003
Laatste: 12-1-2015
26-12-2003 18:09
Quote van tmaudio.nl:
Met DJ-sets van o.a. Richie Hawtin en Sander Kleinenberg is 11 december jl. de Allen & Heath XONE:92 officieel gepresenteerd. Een nieuw topmodel voor de meest veeleisende DJ, met o.a. een dubbele filtersectie, VCA faders, midi - output en 4-bands EQ. Verkoopprijs 1650 Euro excl. BTW.
Denk dat je em dan niet onder de €1500 zo snel zal zien
Logica brengt je van A naar B, verbeelding brengt je overal
Will code for foodStandaard Lid
Sinds: 23-6-2003
Laatste: 14-3-2004
27-12-2003 14:05
Hallo kroket laugh :D
Dan profiteer ik wel even van de veroorzaakte prijsdaling van de xone:62 wink ;)
You Are Now About To Witness The Strength Of Street Knowledge
Sinds: 21-9-2003
Laatste: 3-2-2010
28-12-2003 19:23
dat is gek want op de site staat toch zekerweten 995 pond reken maar uit in euro dat is dus ongeveer 1500 euro
