Omnitronic versterker & Mz Soundline speakers
(12 reacties. Pagina 1 van 2)
RekalStandaard Lid
Sinds: 3-4-2003
Laatste: 26-7-2021
10-3-2005 21:54
Heeft iemand ervaring met Mz Soundline of Omnitronic versterkers ?
ik wil dit setje gaan kopen versterker : 400€ speakers : 300€/stuk
is dit wat ? of heb ik betere alternatieven voor het geld ?
OMNITRONIC p2000
> Powerful PA-amplifier for large stages
> 2 x 1000 W/4 ohms
> Enormous power with highest brilliance
> 2 gain-controls on the frontpanel
> All operation-modes controllable via LEDs
> LED-intensity adjustable via brightness control on the rear panel
> Signal-inputs via XLR-female or 1/4"-jack-socket
> Input sensitivity adjustable via selector on the rear panel
> Speaker connection via lockable Speakon-plugs or Banana/screw combination
> With limiter
> Ground Lift-switch against humming
> Bridged-switch for bridging
> Many protection-circuits for optimized equipment-protection
> Very rugged housing
> 19" dimensions
> High power/weight-relation
> Power supply: 220-250 V AC, 50 Hz ~
or 110-120 V AC, 60 Hz ~
> Power-range: 230 V ± 10 % (206 V - 253 V)
> Power consumption (max.): 3500 W
> Power output sine:
> Stereo 4 Ohm 2 x 1000 W
> Stereo 8 Ohm 2 x 625 W
> 8 Ohms bridged 1 x 1875 W
> Frequency range: 40 - 40 000 Hz, +/- 3 dB
> Damping-factor: > 400
> Distortion factor: 0.01 %
> Signal to Noise Ratio: 90 dB
> Channel seperation (at 1 KHz): 70 dB
> Min. input sensitivity: 0.77 V/26 dB/1.4 V
> Input impedance: 20 kOhms (balanced)
> Slew-rate: 60 V/æsec
> Input-connectors: 2 x XLR-female-plug, 2 x 1/4"-jack-plug
> Output-connectors: 2 x Speakon (stereo), 1 x Speakon (bridge), 2 x Banana/screw combination
> Control elements: Power switch, input attenuators (one per channel), Mode switch - > Stereo/Parallel/Bridged, Ground Lift, Input-Level-Select (0.77 dB, 1.44 dB), limiter
> LED indicators (per channel): Power, Protect, Signal, Mode
> Protection circuits: Short-circuit, DC-protection-circuit, Thermal protection-circuit, > Softstart
> Construction: Steel chassis, aluminium frontpanel
> Dimensions: 470 x 482 x 132 mm
> Minimum mounting depth: 480 mm
> Weight: 29 kg
> Power/weight-relation: 35 W/kg
MZ soundline 152
15"/1" Multifunctionele speaker
Frequentiebereik: 55Hz - 20kHz
Vermogen: 550 Watt RMS / 1100 Watt Peak
Rendement: 97 dB 1w/1m
Impedantie: 8 Ohm
Afmetingen: 430x700x400 mm
Dj antonStandaard Lid
Sinds: 5-10-2003
Laatste: 30-4-2016
10-3-2005 23:06
ik heb zelf een p 1500 van omnitronic in gebruik, werkt op zich prima, gebruik m al zo n 2 jaar, denk dat je in dezelfde klasse zit als de palladium reeks van dap waar ik er ook 4 in gebruik heb.
luidsprekers kan ik niet, van de versterkers kan ik zeggen dat ze voor het geld wel goed zijn. grt anton.
ik wou dat er sets bestonden zo groot als n mini toren.
RekalStandaard Lid
Sinds: 3-4-2003
Laatste: 26-7-2021
10-3-2005 23:38
is wel pakweg 50€ duurder dan hetzelfde in dap - palladium.
een dap p2000 presteert voor 350€ : 2 x 750w op 8 ohm
2 x 1025w op 8 ohm
een Omnitronic p2000 presteert voor 400€ : 2 x 625w op 8 ohm
2 x 1000w op 4 ohm
dus als je vergelijkt is de Omnitronic duurder dan Dap.
maar durf ik dat risoco pakken ? hij moet uiteraard wel beter zijn als de Dap anders ga ik wel voor een Dapje.
EddyCStandaard Lid
Sinds: 24-12-2002
Laatste: 24-11-2024
11-3-2005 09:57
Gebruik nu al een 3-tal jaar de OMNITRONIC P2000 ofwel op 2 ofwel op 4 stuks BR kastje met de 18Sound 15W700 450 Watt RMS.
Naar alle tevredenheid. Enige nadelen : ik denk dat het vermogen overdreven is in de spec sheet. En het gewicht. Heb deze mee in een rack zitten met 2 andere versterkers en dan is 29 kg extra wel zwaar.
--- DB CoolCapies Sound System --- specialiteit goet - foud feestjes !!!
LoungerzStandaard Lid
Sinds: 5-10-2004
Laatste: 25-8-2005
11-3-2005 10:26
3 x bewerkt. Laatst door Sylvia op 12-3-2005 14:27
Edit Mod: Topic opgeschoond. Niet meer van die onzin praten over andere forumleden - Sylvia
Sinds: 5-10-2003
Laatste: 30-4-2016
12-3-2005 12:03
denk ook wel dat je voor het geld ook beter kan gaan voor de palladium reeks,k heb zelf ook 2 palladiums 1600, en die leveren meer als de omnitronic p 1500 en zijn iets goedkoper.
grt anton.
RekalStandaard Lid
Sinds: 3-4-2003
Laatste: 26-7-2021
14-3-2005 06:17
na ook deze post gelezen te hebben : /forum/read/?t=13658
en al de toch aardige comentaren over de dap p-2000.
denk ik dat ik zeker niet a-velinks ga doen en mooi kies voor een dapje.
Bij deze bedankt voor de info. ( en ik ga een dap p2000 kopen (hier bestellen wink ;) ) ).
Sntho0Standaard Lid
Sinds: 14-5-2004
Laatste: 16-9-2023
14-3-2005 08:47
Weet je het wel zeker? Wat denk je van de beveiliging? Toch niet onbelangrijk.
Op de Omnitronic zitten limiters. Op de DAP niet.
En, over de Omnitronic kan ik nergens iets negatiefs vinden in tegenstelling tot DAP.
FerdyStandaard Lid
Sinds: 19-3-2003
Laatste: 23-12-2009
14-3-2005 09:06
Over de omnitronic is ook niks geschreven,die heeft simpelweg minder dealers en wordt dus minder verspreid. DAP is bekender en wordt door meer dealers verspreid waardoor je meer kans hebt dat hij bij mensen in het rack zit. Het aantal (slechte) reviews zal bij de DAP dan ook hoger liggen dan bij de omnitronic, waar toch niemand wat over schrijft omdat ze hem simpelweg niet in hun bezit hebben
Sntho0Standaard Lid
Sinds: 14-5-2004
Laatste: 16-9-2023
14-3-2005 09:45
Ferdy schreef:
Over de omnitronic is ook niks geschreven,....................
Inderdaad wordt er over Omnitronic op deze site niet of nauwelijks iets geschreven, maar er zijn meer sites. Ik wil ook een nieuwe versterker aanschaffen en zoek het hele web na of ik ergens info vandaan kan halen. Ook heb ik bij bedrijven geinformeerd die zowel DAP als Omnitronic verkopen. Ook in Duitsland. Ik heb nog niets negatiefs ontvangen of gelezen over de versterkes van Omnitronic. Trouwens, ik kraak DAP niet af hoor. Ik heb zelf ook DAP versterkes gehad en nooit problemen mee gehad.
