Omnitronic versterker & Mz Soundline speakers
RekalStandaard Lid Uit: België Sinds: 3-4-2003 Laatste: 26-7-2021 Berichten: 278 | 10-3-2005 21:54 |
Heeft iemand ervaring met Mz Soundline of Omnitronic versterkers ? ik wil dit setje gaan kopen versterker : 400€ speakers : 300€/stuk is dit wat ? of heb ik betere alternatieven voor het geld ? OMNITRONIC p2000 > Powerful PA-amplifier for large stages > 2 x 1000 W/4 ohms > Enormous power with highest brilliance > 2 gain-controls on the frontpanel > All operation-modes controllable via LEDs > LED-intensity adjustable via brightness control on the rear panel > Signal-inputs via XLR-female or 1/4"-jack-socket > Input sensitivity adjustable via selector on the rear panel > Speaker connection via lockable Speakon-plugs or Banana/screw combination > With limiter > Ground Lift-switch against humming > Bridged-switch for bridging > Many protection-circuits for optimized equipment-protection > Very rugged housing > 19" dimensions > High power/weight-relation > Power supply: 220-250 V AC, 50 Hz ~ or 110-120 V AC, 60 Hz ~ > Power-range: 230 V ± 10 % (206 V - 253 V) > Power consumption (max.): 3500 W > Power output sine: > Stereo 4 Ohm 2 x 1000 W > Stereo 8 Ohm 2 x 625 W > 8 Ohms bridged 1 x 1875 W > Frequency range: 40 - 40 000 Hz, +/- 3 dB > Damping-factor: > 400 > Distortion factor: 0.01 % > Signal to Noise Ratio: 90 dB > Channel seperation (at 1 KHz): 70 dB > Min. input sensitivity: 0.77 V/26 dB/1.4 V > Input impedance: 20 kOhms (balanced) > Slew-rate: 60 V/æsec > Input-connectors: 2 x XLR-female-plug, 2 x 1/4"-jack-plug > Output-connectors: 2 x Speakon (stereo), 1 x Speakon (bridge), 2 x Banana/screw combination > Control elements: Power switch, input attenuators (one per channel), Mode switch - > Stereo/Parallel/Bridged, Ground Lift, Input-Level-Select (0.77 dB, 1.44 dB), limiter > LED indicators (per channel): Power, Protect, Signal, Mode > Protection circuits: Short-circuit, DC-protection-circuit, Thermal protection-circuit, > Softstart > Construction: Steel chassis, aluminium frontpanel > Dimensions: 470 x 482 x 132 mm > Minimum mounting depth: 480 mm > Weight: 29 kg > Power/weight-relation: 35 W/kg MZ soundline 152 15"/1" Multifunctionele speaker Frequentiebereik: 55Hz - 20kHz Vermogen: 550 Watt RMS / 1100 Watt Peak Rendement: 97 dB 1w/1m Impedantie: 8 Ohm Afmetingen: 430x700x400 mm | |
Dj antonStandaard Lid Uit: Nederland Sinds: 5-10-2003 Laatste: 30-4-2016 Berichten: 74 | 10-3-2005 23:06 |
ik heb zelf een p 1500 van omnitronic in gebruik, werkt op zich prima, gebruik m al zo n 2 jaar, denk dat je in dezelfde klasse zit als de palladium reeks van dap waar ik er ook 4 in gebruik heb. luidsprekers kan ik niet, van de versterkers kan ik zeggen dat ze voor het geld wel goed zijn. grt anton. | |
ik wou dat er sets bestonden zo groot als n mini toren. | |
RekalStandaard Lid Uit: België Sinds: 3-4-2003 Laatste: 26-7-2021 Berichten: 278 | 10-3-2005 23:38 |
is wel pakweg 50€ duurder dan hetzelfde in dap - palladium. een dap p2000 presteert voor 350€ : 2 x 750w op 8 ohm 2 x 1025w op 8 ohm een Omnitronic p2000 presteert voor 400€ : 2 x 625w op 8 ohm 2 x 1000w op 4 ohm dus als je vergelijkt is de Omnitronic duurder dan Dap. maar durf ik dat risoco pakken ? hij moet uiteraard wel beter zijn als de Dap anders ga ik wel voor een Dapje. | |
EddyCStandaard Lid Uit: België Sinds: 24-12-2002 Laatste: 22-11-2024 Berichten: 75 | 11-3-2005 09:57 |
Gebruik nu al een 3-tal jaar de OMNITRONIC P2000 ofwel op 2 ofwel op 4 stuks BR kastje met de 18Sound 15W700 450 Watt RMS. Naar alle tevredenheid. Enige nadelen : ik denk dat het vermogen overdreven is in de spec sheet. En het gewicht. Heb deze mee in een rack zitten met 2 andere versterkers en dan is 29 kg extra wel zwaar. | |
--- DB CoolCapies Sound System --- specialiteit goet - foud feestjes !!! | |
LoungerzStandaard Lid Uit: Nederland Sinds: 5-10-2004 Laatste: 25-8-2005 Berichten: 3 | 11-3-2005 10:26 |
3 x bewerkt. Laatst door Sylvia op 12-3-2005 14:27 Edit Mod: Topic opgeschoond. Niet meer van die onzin praten over andere forumleden - Sylvia | |
Dj antonStandaard Lid Uit: Nederland Sinds: 5-10-2003 Laatste: 30-4-2016 Berichten: 74 | 12-3-2005 12:03 |
denk ook wel dat je voor het geld ook beter kan gaan voor de palladium reeks,k heb zelf ook 2 palladiums 1600, en die leveren meer als de omnitronic p 1500 en zijn iets goedkoper. grt anton. | |
RekalStandaard Lid Uit: België Sinds: 3-4-2003 Laatste: 26-7-2021 Berichten: 278 | 14-3-2005 06:17 |
na ook deze post gelezen te hebben : /forum/read/?t=13658 en al de toch aardige comentaren over de dap p-2000. denk ik dat ik zeker niet a-velinks ga doen en mooi kies voor een dapje. Bij deze bedankt voor de info. ( en ik ga een dap p2000 kopen (hier bestellen ) ). | |
Sntho0Standaard Lid Uit: Nederland Sinds: 14-5-2004 Laatste: 16-9-2023 Berichten: 199 | 14-3-2005 08:47 |
rekal schreef: ( en ik ga een dap p2000 kopen (hier bestellen ) ).Op de Omnitronic zitten limiters. Op de DAP niet. En, over de Omnitronic kan ik nergens iets negatiefs vinden in tegenstelling tot DAP. | |
FerdyStandaard Lid Uit: Nederland Sinds: 19-3-2003 Laatste: 23-12-2009 Berichten: 331 | 14-3-2005 09:06 |
Over de omnitronic is ook niks geschreven,die heeft simpelweg minder dealers en wordt dus minder verspreid. DAP is bekender en wordt door meer dealers verspreid waardoor je meer kans hebt dat hij bij mensen in het rack zit. Het aantal (slechte) reviews zal bij de DAP dan ook hoger liggen dan bij de omnitronic, waar toch niemand wat over schrijft omdat ze hem simpelweg niet in hun bezit hebben | |
Niets uit deze tekst mag gequote worden zonder toestemming van de schrijver | |
Sntho0Standaard Lid Uit: Nederland Sinds: 14-5-2004 Laatste: 16-9-2023 Berichten: 199 | 14-3-2005 09:45 |
Ferdy schreef: Over de omnitronic is ook niks geschreven,.................... | |
