Forum > PC related Forum
nieuw dingetje van hercules (foto's + lange lap text)
(118 reacties. Pagina 1 van 12)
QuincManStandaard Lid
Sinds: 1-8-2003
Laatste: 15-5-2010
4-10-2003 15:30
1 x bewerkt. Laatst door Tom op 9-10-2003 15:25
www.casejunkies.com/images/artikel_upload/picture_2986.jpg
DJ Console: Fun, easy mixing/scratching dual vinyl-style decks
Mix, scratch and manipulate digital music in real time, from MP3s, WMAs to CDs
Solid design with phosphorescent keys perfect for use under low-light conditions at parties
Tactile controls for vastly superior DJ mixing than with a PC keyboard
Take full control of your music with the DJ Console!
Scratch audio files and CDs
Adjust cue points to create great loops
Adjust BPM (Beats Per Minute) for smooth transitions between tracks
Speed up/slow down music
Optimized DJ sound
Play one track for your audience while previewing another on your headphones to create seamless mixes
Add voice-overs by lowering the music volume with the click of a button, allowing you to talk to your public
An advanced sound card for your PC
16-bit/48KHz sampling, 24-bit ADC/DAC
5.1-channel analog output
High-quality connectors:
Digital optical/coaxial In/Out
MIDI In/Out
5.1-channel output via minijack (3.5mm) or RCA plugs
Stereo Line Input (2 RCA plugs)
¼ inch (6.35mm) stereo microphone Input
¼ inch (6.35mm) stereo headphone Output
Totally portable: bring it anywhere!
USB bus-powered device: no external power source required
Compact size: 235x200x650mm (cover included)
DJ Console includes:
a protective cover that doubles as an inclined base
a shoulder strap for easy transportation
Bundled software
Virtual DJ from Atomix Productions, a full professional DJ software suite
New DJ SE from GMIXON, the easy-to-use DJ mixing software
OTS CD Scratch and OTS DJ demo from OTS
Audio, a virtual turntable CD player and a revolutionary MP3/CD/WAV playback system for DJs, radio stations and music lovers
Storm 2.0 DJ Edition from Storm Music Studio, a powerful audio sequencer
DJ Console Softmapper from Hercules, a powerful mapping interface allowing you to assign keyboard shortcuts to your DJ Console’s controls for hands-on control of audio applications (mapping of digital controls only)
TECHNICAL SPECIFICATIONS
Front Panel Input
- Stereo Line In: 2 RCA input plugs
- Gain/talkover button for microphone input control
- ¼ inch (6.35mm) stereo microphone input plug
Output
- Headphone volume control
- ¼ inch (6.35mm) pre-amplified stereo headphone output plug
Rear Panel Analog audio output
- 6 RCA output plugs for 5.1-channel audio
- 3 1/8 inch (3.5mm) stereo output plugs
Digital audio
- Coaxial Input and Output plugs
- Optical Input and Output plugs
MIDI
- Din 5-pin Midi In and Midi Out plugs
USB plug
Top Panel - 2 vinyl-style decks
- 8 knobs
- 3 sliders
- 28 soft phosphorescent buttons
- 1 mini-stick
- 16 LEDs
Audio specifications - 6-channel audio sampling in 16-bit/48KHz mode
- 24-bit 102dB ADC, 24-bit 106dB DAC
- Optical and coaxial S/PDIF digital In & Out (up to 24-bit)
Compatibility USB
- USB 1.1 (USB Full-Speed) required
- Compatible with USB 2.0 (USB High-Speed)
- Due to the need for a full USB power supply, a dedicated USB root hub is recommended
- 2m USB cable included
Audio
- Microsoft® DirectSound® compatible
- ASIO 2.0 drivers included
- General MIDI™ compatible
SYSTEM REQUIREMENTS
- Desktop/laptop PC with Intel Pentium II 400MHz or compatible
- 64MB RAM
- Operating system: Microsoft Windows 98/98 SE, Me, 2000, XP
- USB 1.1 or USB 2.0 port (dedicated USB root hub recommended)
- Headphones or amplified speakers
- CD-ROM or DVD-ROM drive (CD-DA support recommended)
- Microphone, Internet connection + 100MB free hard disk space for installing bundled software
en nog wat foto's
europe.hercules.com/images/products/87/dj_front.gif
europe.hercules.com/images/products/87/dj_rear.gif
prijs zal rond de 250 euro liggen,
ik hou het toch liever bij mijn eigen setje... alhoewel dit ook wel aantrekklijk (lijkt) gezien mijn omstandigheden
wat denken jullie hiervan? top of flop?
Edit Mod: volgende keer zelf even de loze regels verwijderen, en alleen links gebruiken voor de plaatjes aub,pffffff nou een bav
SybrandStandaard Lid
Sinds: 11-5-2003
Laatste: 2-7-2005
4-10-2003 15:36
voor die prijs?
Nou ja, als het echt wat is! dan zal hij top zijn
Ik vind alleen dat het uiterlijk nogal aan Bart Smit doet denken
Blijf possitief, ook als het te moeilijk is!
YoghurtStandaard Lid
Sinds: 11-8-2002
Laatste: 6-8-2023
4-10-2003 15:43
Play & Que knopjes lijken beetje op die van de Numark cdn 36... Heeft er wel iets van weg... Verder vind ik het een oerlelijk ding...Maar als het het goed doet... razz :p
grtz
SnakeEffect Guru
Sinds: 17-2-2003
Laatste: 19-4-2014
4-10-2003 15:53
Wat ik vreemd vind bij deze prijs is dat er midi-in en midi-out aanwezig is. Verder ziet het me er niet echt betrouwbaar uit, het lijkt wel speelgoed eigenlijk.
Sinds: 1-8-2003
Laatste: 15-5-2010
4-10-2003 16:45
het is eigenlijk een soort externe geluidskaart voor de pc
met wat knopjes er op... dus ik persoonlijk denk dat dit leuk bed8 is voor thuisgebruikers en voor die conrad gastjes maar voor echt drive in gebruik zou ikz elf voor een "echte" set gaan
hercules is nl aardig bekend in de pc wereld (oa radeon gpu's)
Dj JasperStandaard Lid
Sinds: 3-6-2003
Laatste: 7-9-2018
4-10-2003 17:20
Hier moetje toch gewoon nog een cd-speler op aansluiten? Dan heb je ook helemaal niks aan al die functies? Die zitten dan op je cd-speler!
DawizzeStandaard Lid
Sinds: 24-12-2002
Laatste: 9-6-2005
4-10-2003 17:57
Het is volgens mij de bedoeling dat je deze console gewoon op je pc aansluit.
Het is gewoon een externe controller voor mixprogramma's op de computer
zoals atomix ed. Het zelfde principe als bpm studio ed, die heeft ook een bijhorende controller.
Mvg Wim
ReindStandaard Lid
Sinds: 5-11-2002
Laatste: 16-1-2012
4-10-2003 18:48
tsja je hebt er geen raat aan bij je dj set want hij heeft geen uitgang per kanaal en dus kun je hem niet aansluiten op je mixer (naja kan wel maar fijn is een ander verhaal).
Sinds: 1-8-2003
Laatste: 15-5-2010
5-10-2003 11:29
lol
dit is volges mij ook niet zo'n hufter proof apparaat... leuk voor die conrad boys maar niet voor echte dj's/drive-in's... daar heb je bpm/atomix/fruityloops/pcdj/etc. voor
RoeltjeStandaard Lid
Sinds: 19-1-2003
Laatste: 30-9-2015
5-10-2003 15:40
Lijkt me ook bedoelt voor de thuismarkt, mensen die thuis achter hun pc een beetje met muziek willen pielen.
vaj-ta-lie-tie
