FIDEK ENDSTUFE 2 X 1500 W/4 $Ohm
(20 reacties. Pagina 3 van 3)Moderator(s): Dré
JapoStandaard Lid Uit: Nederland Sinds: 16-2-2005 Laatste: 23-2-2005 Berichten: 2 | 16-2-2005 22:07 |
En hier zijn ze dan. De technische gegevens. Ik zal ze in het engels geven. High current toroidal transformer allowing high power output with low noise an low distortion. (Ja dat heb je met ringkern trafo's Substantial protection circuitary like thermal, short circuit, output DC offset, RF protection, power on/off muting built in limiter Selectable input sensitivity at 0dB, +dB or +10dB Balalnced XLR-TRS combo input jack Binding post and Speakon output connectors Front mounted gain controls for easy access Signal, Clip, Protect, Bridge mode and Power LED indicators to monitor performance Output Power (W)RMS 8 Ohm, each channel, stereo (1KHz) 1000W 4 Ohm, each channel, stereo 1400W 8 Ohm, bridged mono (1Khz) 2800W Signal to Noise Ratio >100dB Residual Noise < 70 dB Input sensitivity 2.45V Frequency response 20Hz~20Khz ±0.5dB Input Impedance Unbalanced 10 K Ohm balanced input 20k Ohm Channel seperation >60dB (1kHz); >50dB (10kHz) Maximum input Gain + 18dB slew rate 40V / µS Total Harmonic distortion <0.05% Power consumption unloaded 250W Music power loaded 1800W Full loaded 3600W Gross weight 48kg Dimensions 483 (W) x 470 (D) x 132 (H) mm | |
