Nieuw: Denon DN-X600 2-kanaals effectmixer
(7 reacties. Pagina 1 van 1)
Laatste: 15-4-2025
16-8-2010 22:34
Vandaag kondigde Denon een nieuwe 2-kanaals effectmixer aan. Interne processing is 32 bit en aan boord is een 24 bit 96kHz USB 2,.0 soundcard en volledige midi-ondersteuning.
De volgende effecten zijn beschikbaar:
Delay
Echo
Flanger
Filter
Reverb
Loop
Beat Scratch
BeatBreaker
Hier een foto
Verdere details in het Engels:
• Powerful 2-way EFX Parameter Filter:
1) Cross Over (comb filter)
2) Isolator (Low pass filter/ High pass filter)
• Internal 32-bit Floating DSP Processing and 32-Bit DAC Output for best possible sound
• MAC OSX 10.6.4 and 32/64-bit Windows XP/Vista/Win7 Compatible
• Low latency 32/64 Bit ASIO driver for PC included
• Send/Return control -for use with external effectors
• USB Send/Return routing -for use with DJ software DSP effects such as Traktor
• USB MIDI Clock In BPM Detection -for use with, Traktor, Torq, Ableton, Cubase...etc
• Matrix Input Assignment Selector Knob
• Selectable PFL input gain & program meters
• Split Cue function with Cue/Master pan knob
• Phono Amp with high S/N ratio, equivalent to Denon Hifi products
• Ultra clean Mic Amp to realize a studio console class’ low noise level (EIN -126dBu)
• High sound quality high output Headphone Amplifier
• 45mm High Performance Flex Fader (cross fader) w/tension adjust
• Innofader Pro compatible (for cross fader) *see Audio Innovate for more info
• 45mm custom Alps type Channel Faders
• Channel Fader contour adjustment
• Unique 32-point Cross Fader Contour adjustment with:
Contour Adjust
Cross Fader Start Position off the edge (0~2mm range)
"Thru" function for pure MIDI to control Video fades (VDJ, VSL)
• Fader Start function (channel/cross fader)
• Independent 3-Band Isolator EQ w/Kills (High-Mid-Low)
• Large BPM Display w/various beat/time parameter indicators
• Balanced/Unbalanced Master Output
• Master Output Stereo/Mono switch
• Booth Output w/level control
• Mic Input w/Ducking control & 2-Band EQ
• Various Utility presets to customize user settings
• Ideal Grounding Construction protecting from external noise
• ECO stanby mode (green, energy saving)
• Firmware upgradablle over USB
• Solid Steel chassis construction
• Size 9.8(w) x 3.5(h) 12.4(d) inches
250(w) x 90(h) x 315(d) mm
EriswaStandaard Lid
Sinds: 24-8-2006
Laatste: 21-4-2016
17-8-2010 09:42
Als de kwaliteit hetzelfde is als van de top-end mixers van Denon (wat wel zo lijkt) is dit een heerlijk mixertje. Ik vind het wel weer een paradepaardje van non-design trouwens, maarja... functionaliteit is belangrijker denken we dan maar.....
Malle PietjeStandaard Lid
Sinds: 2-10-2003
Laatste: 23-3-2025
17-8-2010 16:14
Hier nog meer leuks About dj
Alles komt goed....
Ricardo VanilliStandaard Lid
Sinds: 28-11-2004
Laatste: 11-1-2025
17-8-2010 20:27
Lijkt me precies wat ik nodig heb. Volgens beter voor on the road gebruik dan de Pioneer DJM 400 aangezien deze wel een booth/monitor uitgang heeft. Afwachten of het de moeite is om mijn X1500 hiervoor de deur uit te doen.
RV
VoltcontrolStandaard Lid
Sinds: 9-6-2005
Laatste: 29-11-2011
18-8-2010 09:26
Ik wacht met smart op een X1700 zonder effecten (deze zijn redelijk overbodig als je toch meestal via tijdcode draait, voor de effecten/browsing wil je toch een NI X1 oid). Simpelweg een mixer met superhoge bouwkwaliteit.
Ben benieuwd of de faders op de X600 ALPS K serie zijn.
Thinkpads are Star Wars, Macs are Star Trek.
Deejay84Standaard Lid
Sinds: 2-12-2006
Laatste: 10-4-2025
20-8-2010 21:29
Denon DN-MC6000 full mixer and 4 deck MIDI controller
hier ben ik dan weer benieuwd na mixer en midi controller in een en ook nog eens 19inch razz :p ,daar zat ik al flinke tijd op te wachten en dan die prijs shocked 8O .
ben benieuwd hoe deze presteerd.
jammer dat hij pas het einde van het jaar uitkomt sad :( .hoop dat ze bij aboutdj snel deze onder de loep gaan nemen.
mvg ronnie
YourLiVeStandaard Lid
Sinds: 19-5-2004
Laatste: 27-10-2021
21-8-2010 17:21
Die MC 6000 ben ik ook wel benieuwd naar, al vind ik m erg speelgoed-achtig overkomen. Lijkt me erg krap maar je kunt er wel een super compact setje mee bouwen natuurlijk. De prijs is erg scherp maar wel een stuk duurder dan bv hercules of numark...
Sinds: 2-12-2006
Laatste: 10-4-2025
22-8-2010 01:16
is inderdaad stukje duurder tegenover hercules enz.vind het voor een denon product best meevallen de prijs mits het natuurlijk ook wat is.maar denk niet dat we daar zorgen over hoeven te maken.
+ dat ik maar weinig apparaten kan vinden die ook nog eens 19inch zijn.
helemaal mooi zouw zijn als er een twee decks cd-lades inzaten,alhoewel alles in 1 ook nadelen heeft als er bijv. iets kapot gaat(in hoeverre zouw je hem dan nog kunnen gebruiken?).
mvg.
