Denon DN-X1700
(29 reacties. Pagina 1 van 3)Moderator(s): Dré
DréAdministrator Uit: Nederland Sinds: 17-11-2001 Laatste: 23-11-2024 Berichten: 13474 | 1-4-2009 13:50 |
Bij een aantal wellicht reeds bekend (maar nu officieel en inclusief afbeelding): PRESS RELEASE – FOR IMMEDIATE RELEASE Denon Professional DJ Unveils Flagship Digital Mixer D&M Business & Professional Group (Europe) is debuting Denon DJ’s new flagship digital mixer at prolight+sound. The DN-X1700 is an ultimate DJ tool for the top flight professional, incorporating powerful performance features and levels of sound quality and control exceeding anything that has gone before. The DN-X1700 represents an achievement of Denon’s engineering prowess and the Denon DJ team’s close association with top end professionals in the business. Years of consultation and design have gone into the development of a mixer of this calibre, and nothing in its specification and construction has been sacrificed to cost or mass manufacturing concerns. Meticulous attention to detail, layout and component quality, make operation of the DN-X1700 a dream, and Denon’s engineers have provided every facility professional DJs will require; working with vinyl, CD, digital files, laptops and USB storage devices.1 Everything about the DN-X1700 is the best it can be. A 4-channel ‘industry standard’ size table top design, the immediately impressive aspect of the design is the simple spacious layout, with highly tactile controls widely and logically laid out to enable easy operation during performance. This features large high quality rubberised knobs, studio quality 60 mm Alps K Series channel faders, 45 mm FLEX cross fader, high visibility colour LCD display, extended 24 point LED channel and output metering, and LED ring metering around the control knobs. In operation, principal features related to the power and flexibility of the DN-X1700 are its Matrix Input Assignment with digital input and MIDI / USB audio, independent and parametric 3-band EQ with Kill on each channel, and dual independent EFX processors. The two EFX processors are located together, with the 3.5 inch TFT colour LCD positioned directly above, for ease of operation. One or other, or both EFX are selectable per channel, and combined EFX operation is available. Each mixer channel has a discrete MIDI layer, enabling external control of various PC and Mac Audio / Video DJ software applications; with the LED ring indicators switching colour to indicate MIDI operation. USB audio I/O extends to 8 mono/ 4 stereo in / out, making the mixer an extremely high quality USB audio interface. Individual user settings – including for audio, system and MIDI settings – can be exported and imported in file format, saved to a USB memory device, HDD, laptop, etc.. The 32-bit floating point DSP engine at the heart of the DN-X1700 is state-of-the-art. It delivers a level of processing power that provides exceptional performance in terms of signal processing quality and control. To match this processing power Denon has equipped the DN-X1700 with 32-bit digital analogue conversion at the audio output stage. Even the world’s best CD / DVD players and home theatre systems boast 24-bit DA conversion; 32-bit conversion provides additional ‘headroom’ in the conversion process providing an analogue output signal with greater resolution and frequency response. The resultant ultra wideband output signal makes the DN-X1700 one of the best sounding pieces of digital audio equipment ever made for the DJ market. Sound quality is paramount in the DN-X1700. Much of the component layout and quality designed to deliver that is derived directly from Denon’s top of the range AV and audiophile products. This extends to discrete series and switching power supplies, respectively, for the analogue and digital signal paths, and an R-core low noise transformer and custom made capacitors. Vinyl quality is given special attention with a high grade phono FET equalizer circuit derived from the ‘Pure Amp’ circuitry of the Denon PMA SA1 audiophile stereo amplifier; this features an 88 dB signal-to-noise ratio and performance specification to complement the output of the best cartridges. Digital audio inputs and USB ports enable direct digital connection of CD decks, laptops, MP3 players and the like – avoiding degradation of input signals by analogue connections and soundcards of varying quality, and multiple digital analogue and analogue digital conversions; ASIO driver ensures low latency from PC soundcards. The attention to sound quality extends to a high quality, low noise discrete microphone pre-amp and high power discrete headphone amplifier. Full complement of I/Os: • balanced XLR and phono analogue outs • 2 x USB 2.0 ports • 5-pin MIDI output • 4 x digital ins / 1 x digital out (44.1 / 48 / 96 kHz) • EFX send and return • Balanced ¼ inch jack booth outs • Balanced XLR and ¼ inch jack mic inputs • Stereo phono recording outs • 4 x (3.5 mm) Fader Starts | |
SinuzStandaard Lid Uit: Nederland Sinds: 18-5-2004 Laatste: 7-4-2020 Berichten: 199 | 1-4-2009 14:11 |
Phono out! Dat ze daar niet eerder aan gedacht hebben! Edit Mod: Dré. Fabrikant had er beter aan gedaan het gewoon cinch te noemen. Toch moet het wel duidelijk zijn dat phono in deze context slaat op het type stekker ;-) | |
TimDStandaard Lid Uit: Nederland Sinds: 26-9-2004 Laatste: 21-11-2024 Berichten: 350 | 2-4-2009 10:11 |
Niks gezien op de messe | |
SinuzStandaard Lid Uit: Nederland Sinds: 18-5-2004 Laatste: 7-4-2020 Berichten: 199 | 2-4-2009 11:36 |
Een mixer zonder analoge input's lijkt me sowiso best gewaagd, er zijn echt nog steeds mensen die met platen draaien en sommige apparaten zoals bijvoorbeeld de D2 director hebben nog steeds geen digitale output. Overigens vind ik hem ook niet erg mooi, het lijkt wel alsof ze een pioneer kleurenpalet gebruikt hebben voor de foto. | |
DjbirdieStandaard Lid Uit: Nederland Sinds: 10-6-2004 Laatste: 18-10-2023 Berichten: 372 | 2-4-2009 12:00 |
In dit topic op het Denon DJ forum staat veel info over deze nieuwe mixer, welke volgens mij vandaag officieel bekend is gemaakt.. | |
JelmerStandaard Lid Uit: Nederland Sinds: 23-1-2004 Laatste: 23-11-2024 Berichten: 430 | 2-4-2009 23:16 |
En op aboutdj hebben ze beeld. Echte foto's wel te verstaan. | |
The return of the BoomBap | |
DjbirdieStandaard Lid Uit: Nederland Sinds: 10-6-2004 Laatste: 18-10-2023 Berichten: 372 | 2-4-2009 23:22 |
Moet zeggen dat de kleurstelling er op de echte foto's al een stuk beter uitziet! | |
ReindStandaard Lid Uit: Nederland Sinds: 5-11-2002 Laatste: 16-1-2012 Berichten: 3032 | 3-4-2009 18:30 |
En het mooie is... niemand anders heeft de live foto's (tot op heden tenminste). Op dinsdag is er namelijk een importeurs feestje geweest op de D&M stand en ondanks dat de X1700 software matig nog niet af was hadden ze hem er wel al neer gezet en een dj er op laten werken, ding vast gelopen, alle kanalen vol open e.d. en dus heeft men hem voor alle zekerheid maar van de stand af gehaald (was ook maar 1 model) om te voorkomen dat men een verkeerde indruk van het apparaat zou krijgen. Ik heb echter via een contact wel even met de mixer kunnen spelen (mixer werkte na een reboot namelijk weer 100%) en ik was toch wel impressed. Een mooi schem, een lelijke kleurstelling (die godzijdank nog niet 100% vast staat en waar misschien nog wel wat aan gewijzigd kan worden)maar vooral een heel mooi apparaat qua functies waar ook echt over nagedacht is. Na een korte impressie is het apparaat weer weg gezet en na die tijd ook niet meer tevoorschijn gehaald. Ik heb in ieder geval alle engelse en duitse contacten ingezet op het eerste exemplaar en dat ie zo snel mogelijk de AboutDJ kant op moet voor een review. ;-) | |
VictorVIP Lid Uit: Nederland Sinds: 23-8-2002 Laatste: 23-11-2024 Berichten: 5308 | 6-8-2009 09:13 |
Inmiddels staat Reinds uitgebreide verhaal op zijn website: https://www.aboutdj.nl/reviews/mixers/1247-denon-dn-x1700.html Is zelfs de eerste software update al uit die je hier hier zonder registratie kan downloaden met de volgende verbeteringen: Denon DN-X1700 firmware update V1100 Improved MIDI for MAC OS X10.5.7 Improved MIDI clock accuracy for 5pin Improved X1700 initialization Improved preset recall Improved pre/pos side filter characteristic Improved the gap of BeatBreaker display and sound Improved the parameters for MIC EQ and Isolator EQ En vind je hier een filmpje met een korte demo van de DN-X1700: https://www.youtube.com/watch?v=7qgRD8Pq0dc | |
RottentweetieStandaard Lid Uit: Nederland Sinds: 15-1-2009 Laatste: 30-8-2019 Berichten: 8 | 6-8-2009 12:09 |
Erg mooi apparaatje! En vind de kleuren die ze gebruikt hebben nog niet eens zo verkeerd! | |
