Clubspot 250MSD vs. Phantom EHJ250/HTI150
(41 reacties. Pagina 1 van 5)Moderator(s): Dré
DevotionStandaard Lid Uit: Nederland Sinds: 19-9-2004 Laatste: 29-11-2011 Berichten: 93 | 3-10-2005 10:56 |
1 x bewerkt. Laatst door Devotion op 3-10-2005 13:51 Wie kan mij helpen om een keuze te maken tussen de volgende 3 moving heads.Showtec Clubspot 250-MSD: The Club Spot 250 is an affordable and versatile moving-head, which is ideal for use in fi xed installations. It has a strong lightoutput, creates vivid colours and razor sharp images. It has a colour-wheel with 8 colours. The gobowheel contains 7 rotating gobos. One of the gobos is a glass gobo. The high-speed shutter ensures fast strobe effects. The rotating prism gives an extra effect and dimension to your lightshow. Technical Information CH1: 8 dichroic colours CH2: 7 rotating gobos CH3: Gobo rotation CH4: Shutter (1-10hz) CH5: Pan 360 degrees CH6: Tilt 270 degrees CH7: Rotation 30 facet Prism Audio function Pre-programmed chases Master/Slave function Power Supply: 240V/50Hz. Dimensions: 370x300x440 mm. (LxWxH) Weight: 11 Kg Lamp: 250 W. dicharge lamp (250MSD) Showtec Phantom EHJ-250 The Phantom is one of the most compact and brightest moving-heads in the market. Due to its small size and huge light-output, it's suitable for many applications such as mobile DJ's and musicians and for fixed installations in clubs, bars and discotheques. The Mini-Explorer has 7 rotating and interchangeable gobos. The colourwheel with 8 brilliant colours creates magnificent colours for all venues. All functions can be controlled by 10 DMX channels. Specially for easy applications the unit has 6 pre-programmed and music-controlled shows. 8 colours 7 gobos Gobo shake effect High speed shutter 16 bit resolution Auto correction function Pan movement: 530 degrees Tilt movement: 280 degrees Power Supply: 240V/50Hz. Power Consumption: 350W Dimensions: 175x190x160mm (LxWxH) Weight: 2,5 Kg Lamp: 24V/250W EHJ Fuse: F5A Showtec Phantom HTI-150 The Phantom HTI is one of the most compact and brightest moving-heads in the market. Due to its small size and huge lightoutput, it's suitable for many applications such as mobile DJ's, musicians, fixed installations in clubs, bars and discotheques. The Mini-Explorer has 7 rotating and interchangeable gobos. The colourwheel with 8 brilliant colours creates magnificent colours for all venues. All functions can be controlled by 10 DMX channels. Specially for easy applications the unit has 6 preprogrammed and music-controlled shows. 8 colours 7 gobos Gobo shake effect High speed shutter 16 bit resolution Auto correction function Pan movement: 530 degrees Tilt movement: 280 degrees Power Supply: 240V/50Hz Power Consumption: 350W Dimensions: 175x190x160mm (LxWxH) Weight: 2,5 Kg Lamp: HTI-150 Fuse: F5A Het gaat mij niet om de prijsverschillen tussen de headjes maar om de eigenschappen van die dingen. Wie is er bijvoorbeeld in het bezit van een van deze of heeft er ooit mee gewerkt en kan dus de specificaties bevestigen wat zijn gegeven door showtec. Dit zijn namelijk de gegevens uit de catalogus en die kloppen niet altijd zoals we al vaker gemerkt hebben. Heeft de Clubspot bijvoorbeeld echte rotating gobo's en een roterend prisma ? en is de clubspot wle of geen 16bit resolutie ? want in de catalogus staat dus in de specificaties, zoals hierboven vermeld, dat deze dat niet zou kunnen. Maar in de catalogus staat dus ook een afbeelding van de bezetting van de DMX kanalen waarbij dus een kanaal 8 en 9 zijn waar de 16bit resolutie in staat. En dan de verschillen tussen de lampen opzicht. Ik weet natuurlijk ook wel dat kwa licht de clubspot er het beste gaat uitkomen omdat hier een 250 watt ontladingslamp in zit. Maar hoe zit het bij de Phantom welke heeft het beste licht ? De 250 W halogeen of de 150 W ontladingslamp ? | |
Luc2366Standaard Lid Uit: België Sinds: 8-4-2003 Laatste: 15-6-2017 Berichten: 686 | 3-10-2005 12:12 |
Uit de Phantom komt GEEN licht, heb er al mee gewerkt. Zoek je een goede/degelijke 250 MSD-head, kijk eens naar de HQ-Power Pro-spot250 | |
Big bangVIP Lid Uit: Nederland Sinds: 4-11-2003 Laatste: 22-9-2024 Berichten: 2389 | 3-10-2005 12:27 |
1 x bewerkt. Laatst door Big bang op 3-10-2005 14:45 luc2366 schreef: Uit de Phantom komt GEEN licht, heb er al mee gewerkt.Dre was anders behoorlijk positief over de output. Kun je wat specefieker zijn? Onder andere welke van de twee phantoms je mee hebt gewerkt? Leuk zulke meningen, maar onderbouw ze dan ook even | |
DréAdministrator Uit: Nederland Sinds: 17-11-2001 Laatste: 24-11-2024 Berichten: 13474 | 3-10-2005 13:24 |
Positief over een EHJ 250 moving head z'n output betekent natuurlijk niet dat je hem ook maar even kunt vergelijken met een MSD 250 moving head!!! Hopelijk snap je dat zelf ook wel. | |
DevotionStandaard Lid Uit: Nederland Sinds: 19-9-2004 Laatste: 29-11-2011 Berichten: 93 | 3-10-2005 13:53 |
Ja dat snap ik maar heb je ook de verschillen gezien tussen de 250W halogeen en de 150W HTI ? Welke van deze twee komt er dan beter uit ? en is de phantom echt 16 bits resolutie ? | |
Big bangVIP Lid Uit: Nederland Sinds: 4-11-2003 Laatste: 22-9-2024 Berichten: 2389 | 3-10-2005 14:45 |
Dré schreef: Positief over een EHJ 250 moving head z'n output betekent natuurlijk niet dat je hem ook maar even kunt vergelijken met een MSD 250 moving head!!! Hopelijk snap je dat zelf ook wel. | |
JanboStandaard Lid Uit: Nederland Sinds: 3-8-2004 Laatste: 8-6-2010 Berichten: 231 | 3-10-2005 17:29 |
De clubspot 250 (of een 100% kloon daarvan, niet onthouden) heb ik een keertje gebruikt. Komt goed licht uit in vergelijking met HTI/EHJ (logisch), komen zelfs mee met de Movitec's SL-250 die ik er toen bij had. Voor normaal gebruik zijn ze ook snel genoeg. De afwerking viel me echter erg tegen met goedkoop aandoend plastic. Dat plastic sluit ook niet overal even goed en zou op termijn wel eens tot lichtlekkage kunnen leiden. En vooral: ze maken een enorme bak herrie. NB. De clubspot heeft WEL roterende gobo's, GEEN prisma en ik meen WEL 16-bit. | |
Luc2366Standaard Lid Uit: België Sinds: 8-4-2003 Laatste: 15-6-2017 Berichten: 686 | 3-10-2005 18:29 |
ik heb die phantoms gebruikt met 8 tegelijk op een trussje van 4mtr hoog. Die dingen geven gewoon geen licht af en zeker niet als je ze gaat kombineren met scans en/of par's. Lijkt me logisch als de OP de keuze geeft tussen MSD/HTI en ENH dat de gewone halogeen al direct afvalt... Zoals eerder bevestigd werd door anderen: het alternatief op de Movitec/Robe (waar ik mee gewerkt heb) deed het gewoon netjes, kwam veel licht uit, maakte niet meer herrie dan anderen en behuizing zag er ok uit. Deze zijn duurder dan de ENH- en HTI-versie maar was voor mij de moeite waard om ervoor door te sparen. Een headje is volgens mij niet iets om "te hebben" maar om "mee te werken" en zijn GEEN vervanging van scans in een front-trusje. Als je geen roto gobo's hebt, er komt geen licht uit en ze zijn traag - wat ben je er dan mee? | |
DréAdministrator Uit: Nederland Sinds: 17-11-2001 Laatste: 24-11-2024 Berichten: 13474 | 4-10-2005 10:27 |
De Phantom heeft wel roterende gobo's en is wel snel in z'n bewegingen. Voor z'n lampje (3 euro 24V/250W halogeen pitje) komt er prima licht uit. Niet meer, niet minder. M'n Mazda trekt nu eenmaal VEEL beter op dan m'n Hyundai busje... Neemt niet weg dat de Hyundai een prima busje is. | |
DevotionStandaard Lid Uit: Nederland Sinds: 19-9-2004 Laatste: 29-11-2011 Berichten: 93 | 4-10-2005 14:40 |
Ik heb alle antwoorden op m'n vragen... Heb gewoon even contact opgenomen met Highlite zelf en gezegd dat ik het idee had dat er wat drukfouten in de catalogus staan. Toen kreeg ik te horen dat dit klopte ja en over welke producten ik vragen had. Ik toen dus maar even alles gevraagd wat ik moest weten en nu weet ik ook de verschillen tussen de MH's De Showtec Phantom alletwee de versies, alleen de lamp verschild: 8 colours 7 gobos (geen roterende) Gobo shake effect High speed shutter 16 bit resolution Auto correction function Pan movement: 530 degrees Tilt movement: 280 degrees De Showtec Club Spot 250: 8 dichroic colours 7 rotating gobos 7 DMX channels Shutter (1-10Hz.) Geen Prisma 16 Bit resolutie Audio function Pre-programmed chases Master/Slave function Power Supply: 240V/50Hz. Pan movement: 360 degrees Tilt movement: 270 degrees De Showtec Club Spot 575, kreeg ik ook intresse in dus ook maar gevraagd: 8 dichroic colors 7 rotating gobos 7 fixed gobos 12 DMX channels Shutter (1-10Hz) Dimmer Rotating 3-facet prism 16 bit resolution Motorized focus Audio Function Preprogrammed chases Master/Slave Function Digital addressing Fancy blue LED display Pan: 360 degrees Tilt: 270 degrees Power Supply: 240V/50Hz Weight: 11 Kg Channel Settings: CH1: Colorwheel CH2: Rotating Gobowheel CH3: Gobo rotation CH4: Static Gobowheel CH5: Pan CH6: Tilt CH7: Prism CH8: Focus CH9: Shutter/Dimmer CH10: Pan/Tilt Speed CH11: Fine Pan CH12: Fine Tilt En ik denk zelf dat het dan toch de ClubSpot 575 wordt. Heeft namelijk veel functies en alles wat ik wil hebben. Komt wel een enorme bak licht uit maarja is altijd te dimmen. | |
