Lekkere mixer , iets waard??
Tom. VStandaard Lid Uit: België Sinds: 14-4-2004 Laatste: 16-6-2005 Berichten: 497 | 27-4-2004 18:47 |
1 x bewerkt. Laatst door Tom op 27-4-2004 22:58 Hallo iedereen,ik ben zonet mijn droommixer tegengekomen (4 kanalen BPM...) Is dit iets waard ?? RMX-40 BPM New voor foto naar: www.reloop.de mixers RMX-40 BPM specs/features 4+1 channel PRO club mixer Outstanding sound created by Premium Sound Architecture (PSA) Automatic beat counter for all channels (double 3-digit display) Freely assignable Long Life TCT Crossfader (45 mm) with adjustable curve Crossfader Start Play Long Life Linefader (60 mm) with adjustable curve, reversible Metal potentiometer Kill unit for both crossfader channels with flash function (-60 dB) Send/Return effect for all channels Extra LED display per channel for pre-listening signal Gain control with 3-fold sound control (+10 / -40 dB) per channel Mic channel 1 with 3-fold sound control (+10 / -40 dB), Gain, Cue & talk-over Mic channel 2 with 3-fold sound control (+10 / -40 dB), Gain & Cue Ultra high-performance headphones out 1-way equalizer (mono option, Cue-Master-Mix, with mono/stereo switch) 2 adjustable master outputs with balancing function (with mono/stereo switch and trim control) Outputs: 2 Master (Master 1: XLR/Cinch, Master 2: Cinch), 1 Rec (Cinch), 1 Send (6.3 mm jack) Inputs: 4 phono (Cinch), 4 (+4) Line (Cinch), 2 Mic (Mic 1: Combi, Mic 2: 6.3 mm jack), 1 return (6.3 mm jack) technical Frequency range: 20 Hz - 20 kHz S/N ratio: -80 dB Distortion: 0.01% Dimensions: 320 x 357 x 87 mm Weight: 5.6 kg info The models from the 40s series are premium RMX consoles: All channels have reversible faders with variable curves and their respective level LEDs and automatic Beat Counters. The Crossfader controls all input channels, activates the sources via Fader Start and cuts their frequencies with the Kill Switches. Highly DJ-friendly is the headphone output with equalizer and mono switch. The DSP design also offers a complete effects section. Alvast bedankt !! Grts Tom . V Edit Mod: volgende keer de enter wat minder gebruiken graag, Tom | |
19/08/2005: FORTIVITY : VERBRUGGEN VS REGNEZALS, GHOST, WOUT, SVEN LANVIN | |
DréAdministrator Uit: Nederland Sinds: 17-11-2001 Laatste: 18-9-2024 Berichten: 13471 | 27-4-2004 18:55 |
Deze mixer komt pas in de loop van de zomer. Tot die tijd kan er niet veel meer over gezegd worden dan dat hij er goed uitziet (maar da's bij wel meer mixers het geval...). | |
DjluzoStandaard Lid Uit: Nederland Sinds: 17-6-2003 Laatste: 24-9-2005 Berichten: 147 | 27-4-2004 20:15 |
ziet er BIJNA hetzelfde eruit als de djm 600, djx 700, denon x1500. alleen de koptelefoon knopjes zijn anders en hier zitten kill butons op | |
Luuk | |
DiederikStandaard Lid Uit: Nederland Sinds: 20-5-2003 Laatste: 3-2-2021 Berichten: 619 | 27-4-2004 20:37 |
1 x bewerkt. Laatst door Diederik op 27-4-2004 21:20 Hoewel je eigenlijk per product moet kijken en niet naar het merk, veronderstel ik dat je reloop eerder in de buurt van Behringer kunt zetten dan Denon en Pioneer. Maar wie weet heeft Reloop cq de ontwikkelaar van deze mixer (Reloop is tenslotte ook grotendeels maar een dozenschuiver) geleerd van de fouten die gemaakt zijn bij de DJX-700 (prutsfaders, effecten die niet BPM synchroon zijn (hoewel deze mixer geen effecten heeft)), zodat er een best wel leuke mixer uit gaat komen.Maarja zo lang ie nog niet verkrijgbaar is, en er een aantal van in de omloop zijn is en blijft het natuurlijk giswerk. Daar heb je dus vrij weinig aan. ziet er BIJNA hetzelfde eruit als de djm 600, djx 700, denon x1500. alleen de koptelefoon knopjes zijn anders en hier zitten kill butons op Hij heeft geen effecten voor zover ik dat kan opmaken uit de site van reloop dus de vergelijking met de djm-600, djx-700 en x-1500 gaat niet helemaal (helemaal niet ) op.[edit: toch wel dus...] | |
Wat nu heel gewoon is, was ooit een revolutie | |
RemczeroStandaard Lid Uit: Nederland Sinds: 2-11-2002 Laatste: 26-2-2010 Berichten: 336 | 27-4-2004 21:17 |
Diederik schreef: Hij heeft geen effecten voor zover ik dat kan opmaken uit de site van reloop dus de vergelijking met de djm-600, djx-700 en x-1500 gaat niet helemaal (helemaal niet ) op.The DSP design also offers a complete effects section. De mixer ziet er inderdaad zeer interesant uit. Als de kwaliteit ook wat is is het misschien ook wel wat voor mij ,maar laat je niet verblinden door de kiekjes van een product (zie onderandere de djx700 van behringer ,en kijk dan maar eens naar wat het apparaat kwalitatief voorsteld). | |
DiederikStandaard Lid Uit: Nederland Sinds: 20-5-2003 Laatste: 3-2-2021 Berichten: 619 | 27-4-2004 21:19 |
whooopss..lange dag gehad | |
DJ Dave-QStandaard Lid Uit: Nederland Sinds: 25-4-2003 Laatste: 13-11-2006 Berichten: 75 | 28-4-2004 06:16 |
remczero schreef: Diederik schreef: Hij heeft geen effecten voor zover ik dat kan opmaken uit de site van reloop dus de vergelijking met de djm-600, djx-700 en x-1500 gaat niet helemaal (helemaal niet ) op.The DSP design also offers a complete effects section. er is inderdaad ook een RMX-40 DSP, maar da's niet het model waar jij het over had in de startpost (BPM) | |
Music is the answer! GEAR: 2x Gemini PT-2400 + Concorde Pro's, Dateq XTC, Pioneer HDJ-1000 | |
RemczeroStandaard Lid Uit: Nederland Sinds: 2-11-2002 Laatste: 26-2-2010 Berichten: 336 | 28-4-2004 08:22 |
Dan hebben ze gewoon een standaart tekstje bij elke mixer staan ,want het staat er toch echt. | |
8pmStandaard Lid Uit: Nederland Sinds: 2-6-2004 Laatste: 10-3-2005 Berichten: 4 | 16-12-2004 22:14 |
Klein bescheiden schopje ... Ik zag dat de mixer ondertussen als direct leverbaar is opgenomen in de Webshop, kun je al iets meer over de mixer(s) vertellen Dre ?? | |
... always in a State of Trance ... | |
MaikStandaard Lid Uit: Nederland Sinds: 19-10-2004 Laatste: 6-6-2008 Berichten: 6 | 17-12-2004 09:31 |
Ik ben ook erg benieuwd | |
