Lekkere mixer , iets waard??
(21 reacties. Pagina 1 van 3)
Tom. VStandaard Lid
Sinds: 14-4-2004
Laatste: 16-6-2005
27-4-2004 18:47
1 x bewerkt. Laatst door Tom op 27-4-2004 22:58
Hallo iedereen,
ik ben zonet mijn droommixer tegengekomen (4 kanalen BPM...)
Is dit iets waard ??
RMX-40 BPM New
voor foto naar: www.reloop.de
mixers
RMX-40 BPM
specs/features
4+1 channel PRO club mixer
Outstanding sound created by Premium Sound Architecture (PSA)
Automatic beat counter for all channels (double 3-digit display)
Freely assignable Long Life TCT Crossfader (45 mm) with adjustable curve
Crossfader Start Play
Long Life Linefader (60 mm) with adjustable curve, reversible
Metal potentiometer
Kill unit for both crossfader channels with flash function (-60 dB)
Send/Return effect for all channels
Extra LED display per channel for pre-listening signal
Gain control with 3-fold sound control (+10 / -40 dB) per channel
Mic channel 1 with 3-fold sound control (+10 / -40 dB), Gain, Cue & talk-over
Mic channel 2 with 3-fold sound control (+10 / -40 dB), Gain & Cue
Ultra high-performance headphones out 1-way equalizer (mono option, Cue-Master-Mix, with mono/stereo switch)
2 adjustable master outputs with balancing function (with mono/stereo switch and trim control)
Outputs: 2 Master (Master 1: XLR/Cinch, Master 2: Cinch), 1 Rec (Cinch), 1 Send (6.3 mm jack)
Inputs: 4 phono (Cinch), 4 (+4) Line (Cinch), 2 Mic (Mic 1: Combi, Mic 2: 6.3 mm jack), 1 return (6.3 mm jack)
technical
Frequency range: 20 Hz - 20 kHz
S/N ratio: -80 dB
Distortion: 0.01%
Dimensions: 320 x 357 x 87 mm
Weight: 5.6 kg
info
The models from the 40s series are premium RMX consoles: All channels have reversible faders with variable curves and their respective level LEDs and automatic Beat Counters. The Crossfader controls all input channels, activates the sources via Fader Start and cuts their frequencies with the Kill Switches. Highly DJ-friendly is the headphone output with equalizer and mono switch. The DSP design also offers a complete effects section.
Alvast bedankt !!
Grts Tom . V
Edit Mod: volgende keer de enter wat minder gebruiken graag, Tom
19/08/2005: FORTIVITY : VERBRUGGEN VS REGNEZALS, GHOST, WOUT, SVEN LANVIN
Laatste: 21-11-2024
27-4-2004 18:55
Deze mixer komt pas in de loop van de zomer. Tot die tijd kan er niet veel meer over gezegd worden dan dat hij er goed uitziet (maar da's bij wel meer mixers het geval...).
DjluzoStandaard Lid
Sinds: 17-6-2003
Laatste: 24-9-2005
27-4-2004 20:15
ziet er BIJNA hetzelfde eruit als de djm 600, djx 700, denon x1500. alleen de koptelefoon knopjes zijn anders en hier zitten kill butons op
Luuk
DiederikStandaard Lid
Sinds: 20-5-2003
Laatste: 3-2-2021
27-4-2004 20:37
1 x bewerkt. Laatst door Diederik op 27-4-2004 21:20
Hoewel je eigenlijk per product moet kijken en niet naar het merk, veronderstel ik dat je reloop eerder in de buurt van Behringer kunt zetten dan Denon en Pioneer. Maar wie weet heeft Reloop cq de ontwikkelaar van deze mixer (Reloop is tenslotte ook grotendeels maar een dozenschuiver) geleerd van de fouten die gemaakt zijn bij de DJX-700 (prutsfaders, effecten die niet BPM synchroon zijn (hoewel deze mixer geen effecten heeft)), zodat er een best wel leuke mixer uit gaat komen.
Maarja zo lang ie nog niet verkrijgbaar is, en er een aantal van in de omloop zijn is en blijft het natuurlijk giswerk. Daar heb je dus vrij weinig aan.
Hij heeft geen effecten voor zover ik dat kan opmaken uit de site van reloop dus de vergelijking met de djm-600, djx-700 en x-1500 gaat niet helemaal (helemaal niet wink ;)) op.
[edit: toch wel dus...]
RemczeroStandaard Lid
Sinds: 2-11-2002
Laatste: 26-2-2010
27-4-2004 21:17
Ik quote de Reloop site:
De mixer ziet er inderdaad zeer interesant uit. Als de kwaliteit ook wat is is het misschien ook wel wat voor mij ,maar laat je niet verblinden door de kiekjes van een product (zie onderandere de djx700 van behringer ,en kijk dan maar eens naar wat het apparaat kwalitatief voorsteld).
Sinds: 20-5-2003
Laatste: 3-2-2021
27-4-2004 21:19
whooopss..lange dag gehad
DJ Dave-QStandaard Lid
Sinds: 25-4-2003
Laatste: 13-11-2006
28-4-2004 06:16
wat weer niks over deze mixer zegt aangezien dit niet het DSP model is maar de BPM.
er is inderdaad ook een RMX-40 DSP, maar da's niet het model waar jij het over had
in de startpost (BPM) wink ;)
Music is the answer! GEAR: 2x Gemini PT-2400 + Concorde Pro's, Dateq XTC, Pioneer HDJ-1000
Sinds: 2-11-2002
Laatste: 26-2-2010
28-4-2004 08:22
Dan hebben ze gewoon een standaart tekstje bij elke mixer staan ,want het staat er toch echt.
8pmStandaard Lid
Sinds: 2-6-2004
Laatste: 10-3-2005
16-12-2004 22:14
Klein bescheiden schopje ...
Ik zag dat de mixer ondertussen als direct leverbaar is opgenomen in de Webshop, kun je al iets meer over de mixer(s) vertellen Dre ??
... always in a State of Trance ...
MaikStandaard Lid
Sinds: 19-10-2004
Laatste: 6-6-2008
17-12-2004 09:31
Ik ben ook erg benieuwd happy :)
