Nieuwe 4 kanaals mixer van DATEQ: Vibe
(296 reacties. Pagina 4 van 30)
vorige 1 2 3 4 5 6 .. 30 volgende
DJDarknessStandaard Lid
Sinds: 2-4-2004
Laatste: 22-12-2009
15-3-2005 22:35
Waarom is dateq eigelijk van zijn befaamde 100mm faders af gestapt?
Dat was juist iets waarvoor iedreen dateq graag had..
Where words fail, music speaks :D
SylviaEx Lid
Sinds: 12-1-2003
Laatste: 11-11-2011
15-3-2005 22:42
En ook juist waarom een hoop anderen geen Dateq wilden.
Sinds: 2-4-2004
Laatste: 22-12-2009
15-3-2005 22:50
Ja, dat is ook wel weer waar....
Mischien twee varianten leveren?? wink ;)
1 100mm en 1 60mm happy :)
QuincManStandaard Lid
Sinds: 1-8-2003
Laatste: 15-5-2010
15-3-2005 22:55
The long awaited professional DJ mixer has finally arrived !
The Vibe has five channels, four of which are equipped with faders. The channel without fader is meant to enable microphones or auxiliary sources to be used without occupying one of the 4 main channels. In total 9 stereo sources and one microphone input is available. Microphone level can still be adjusted with the Gain-control, and a special “Rap” switch makes it possible to turn very quickly to the preset level of that channel. The fader channels are equipped with medium length, 60 mm ALPS fader which runs extremely smoothly. The VIBE channels consist of two inputs each, so that line signals such as computer, sampler, CD or MD player can be connected as well as three turntables. A push button next to the channel input control allows switching from input 1 to input 2, so that plugging in and unplugging equipment is a thing of the past.
The tone control is just what can be expected from Dateq. A perfect Top for accentuating high hats, an aggressive Mid and a Groovy Bass. Top and Bass have a range of plus 8 to minus 32 dB, while the Mid band can be adjusted from minus 34 to plus 6 dB. So the need for kill switches is eliminated.
The first microphone channel has a dedicated 4-way tone control with a sub-low band, to eliminate the ultra low “plop” frequencies and still maintain a warm full sound.
A processor makes it possible to tune your Vibe mixer to your personal taste in control settings.
This way you can personalize your own personal DJ tool.
The X-fader is selectable between the four fader-channels of the Vibe and is together with the channel faders VCA operated, in order to exclude noise and to guarantee years of trouble-free use.
The two Multi Band Filters are designed for changing the music just way you would like it.
By using two filters at a time, spectacular mixes between two different sources can be created.
The control of the filters can be done through manual rotation or by the cross-fader.
To add even more flexibility each fader channel can choose to switch in the send/return path to allow external effects to be connected for optimum performance. To make it complete, a separate 20 segments VU meter can show the input and output level of the FX line.!
This allows you to add external effects without the unwanted distortion, due to a too high level.
Each channel can be monitored on a powerful headphone-output. Split, a unique Dateq function, can be tuned from the full Source, to the full Cue signal.
This allows monitoring and listening to the master signal to be carried out on the headphones simultaneously.
There are plenty of outputs available on the Vibe. The master output is balanced and has XLR plugs so that it can be coupled directly to an output amplifier. The master also has a cinch output. The XTC has a monitor out, a Sub low output for operation of an (active) low speaker and a second headphone connection.
Also a RJ45 socket is provide to allow fast software updates in the future. A MIDI connection allows you to personalize start/stop settings to computers etc.
Because the Vibe is used mostly in dimly lit surroundings, it is equipped with a front-mounted 12 volt BNC-lamp connection.
bron: clubcharts forum
DJ TimStandaard Lid
Sinds: 9-6-2003
Laatste: 27-11-2012
16-3-2005 09:04
Ik weet het niet als ik het zo lees. Als dat ding rond de 1200 snork moet kosten denk ik toch dat de meesten er hun geld niet insteken. Er is namelijk weinig nieuws in de mixer wat andere merken niet bieden (Xone serie en voor 400 meer heb je een :92 of je hebt voor minder een nuo 5) en ze hebben nog steeds die &*^$$#@# Split functie.
Ondanks dat ik Dateq fan ben laten ze denk ik een steekje vallen.
Als het ding modulair is opgebouwd misschien weer niet. Ben wel benieuwd hoe de mixer eruit ziet. Eigenlijk is het nog erg gissen dus.
Ik ben niet het eerste wereldwonder maar ben er wel geweest
FredjeStandaard Lid
Sinds: 2-3-2003
Laatste: 20-5-2008
16-3-2005 19:08
Ik zit te springen om dat 4 kanaals ding van ze.
Maar vind m erg aan de prijs.
ik weet nu al dat ik m niet nieuw ga kopen,een jong occasion is beter.
Persoonlijk vind ik dat je een upgrade van een bestaand mengpaneel(zo zie ik het)percentagegewijs wat meer mag kosten.
Ho ho specialisten onder ons,er kan van alles beter zijn en luxer en weet ik veel-maar de halve wereld zit te wachten op een 4 kanaals uitvoering van de xtc en zo word het ook gebracht door Dateq.
Mij zal het worst wezen hoe of wat.
boem-kom op met die 4 kanaals mixer en verhoog de prijs percentagegewijs,in mijn ogen is dan een verhoging van twee a driehonderd een keurig gegeven.
En veel liefhebbers gaan over tot koop.
Voor die 1200 euro kom ik ineens in een ander segment terecht en met wat minder of meer bij of van die 1200 is er zo veel meer dan dateq heeft of geeft.
Wat willen ze nou,moet ik zo gecharmeerd worden van een 4 kanaals mixertje en daar zo blij mee zijn dat ik ff 1200 euro uitgeef.
De xtc is met goed zoeken(acties etc etc) om en nabij de 650 euro te verkrijgen-dan een prijs van 850 tot 950 euro vind ik echt de grens.
Ik wil m zeker maar ben niet bereid om dat geld er voor neer te leggen,want voor 550 meer dat ene kanaal extra te hebben-ze zijn gek.
Let wel-ik wil gedegen en basic!!Daar betaal ik voor bij de XTC.
Ik werk en ben tevreden(tuurlijk weet ik dingen die beter zouden zijn)met de xtc.
groet
it's just one of those Day's ,they come and they Go.
Sinds: 1-8-2003
Laatste: 15-5-2010
16-3-2005 21:39
Amazing sh*t mike! Dat ga ik eens nader bespeuren zodra er meer bekend is over de mixer/wanneer ik m kan testen in een shop.
DJ TimStandaard Lid
Sinds: 9-6-2003
Laatste: 27-11-2012
17-3-2005 09:07
Er zijn toch ook geruchten dat de NUO 4 met midi uit gaat komen? En nog steeds, als ik 1200 snork moet dokken voor een Dateq 4 kanaals, leg ik er liever wat bij en koop een LPM (2e hands is een GPM zelfs voor dat geld te krijgen) en dan weet je zeker dat je een beest van een mixer in huis hebt die je meeneemt in je graf.
Over dat 60mm verhaal, je kon erop wachten dat Dateq hier mee zou komen, ze hebben zelfs op hun site (weet niet of het nog steeds zo is) een stemming gedaan wat dj's nou het liefst voor fader lengte wilden hebben, meesten wilden 60.
Daarom denk ik ook dat Dateq probeert met deze mixer andere segmenten te veroveren, het enige jammere is dat ze tenonder gaan aan hun eigen succes, ze hebben te lang op hun bestaande series geteerd, terwijl van links naar rechts de effectenmixers en battle mixers en zelfs de Xone series oprukten. En volgens mij zie je buiten nederland en België nergens een Dateq terug. Ze hadden in de tijd dat er nog overal Dateq stond in de Nederlandse club ook meteen wat meer internationaal moeten doen.
SylviaEx Lid
Sinds: 12-1-2003
Laatste: 11-11-2011
17-3-2005 09:37
Het is maar de vraag of Dateq internationale ambities heeft. Verder pretenderen ze volgens mij nergens een effectenmixer- of battlemixerfabrikant te zijn. Sommige fabrikanten maken alles, anderen richten zich meer op één ding, en daar waar het gaat om dj/clubmixers is het ons Nederlandsers allemaal volstrekt helder waar Dateq op mikt: robuust, betrouwbaar en no-nonsense. Dat is ook precies wat ze groot heeft gemaakt in Nederland.
Wat betreft de prijs: de XTC was ooit ook veel duurder. Eerst maar eens zien wat die nieuwe mixer te bieden heeft, daarna beslis ik wel of hij het waard is of niet.
Ik moet eerlijk zeggen dat ik ook érg benieuwd ben naar het design, of daar nog iets aan veranderd is ten opzichte van de huidige lijn.
DJ TimStandaard Lid
Sinds: 9-6-2003
Laatste: 27-11-2012
17-3-2005 10:09
Ik weet wel zeker dat Dateq geen internationale ambities heeft en ook nooit heeft gehad. Ik weet ook dat ze niet in het battle of effectensegment wilden knoeien.
Wat ik wel weet is dat bij Dateq al een heel lange tijd de tijd heeft stilgestaan en dat (en dat vind ik heel jammer) zo'n beetje iedere club of party nu gedaan wordt met een Pioneer DJM 600 of een A&H.
Veel dj's vragen tegenwoordig om dingen zoals filters en effecten en dus wordt iedere Dateq eruit gekwakt. De mooiste verkoopcijfers bij Dateq zijn dus ook verleden tijd denk ik, of ze moeten mee gaan met de meute en tegen een prijs die kan mee komen met Ecler en A&H mixers maken die kwalitatief even goed of beter zijn met de hele rommel erop.
Daarnaast zijn Dateq mixers (de LPM en GPM serie tenminste) zo ontzettend goed dat je er praktisch een leven lang op kan draaien. Dus een destijds 10 jaar oude LPM of GPM kan nog steeds heel goed ermee door als je af- en toe de boel schoonmaakt of een fader vervangt, zeker als je een beetje zuinig bent op het spul, dus er zijn ook mensen die hun Dateq gewoon niet hoeven te vervangen.
Ik denk dat mensen die begonnen zijn met draaien op Dateq voordat er mixers uitkwamen met effecten en andere troep misschien wel Dateq zullen blijven kopen omdat ze weten dat ze lekker werken en betrouwbaar zijn, maar zelfs dat segment zie je een beetje neigen naar mixers met de hele bende erop.
