Final Scratch 2
(155 reacties. Pagina 1 van 16)
DjProbeStandaard Lid
Sinds: 1-7-2004
Laatste: 6-8-2009
15-9-2004 18:25
www.finalscratch.com/fs4/start.asp
-Ships November 1st $799 First time User
-FULLY ASIO SOUND CARD
-New cool Design
-Midi In/out
-Mic with XLR & 1/4" plug ins (yes just like SSL we can now Scratch our own voice live)
-Firewire Interface 2 Plugs maybe for Possible Daisy Chaining
-SA controlled Gains for each Line and the Mic
-Headphone jack in the SA and Gain for that
-24 bit/96 kHz sound quality
-ScratchAmp 2 is passive, you can run audio through the amp without power.
-A FireWire Thru port lets you connect an iPod™ or external hard drive.
-Auxilary Input
-This latest version of the TRAKTOR DJ Studio 2.6 is compatible with FinalScratch 2
-Seemless Looping (only availible with TRAKTOR DJ Studio 2.6) :( (Preproduced Loops with just TFS)
-Support for WMA and AAC formats
-Record your live mix directly to the hard drive in WAV or AIFF formats
-Print Your Playlists
-Cue Points
-Minute Markers in Small Waveform to help guide your mix
community.webshots.com/photo/186947004/186947323kemast
community.webshots.com/photo/186947004/187050147YgSXcG
Features
NEW: 24bit/96kHz FireWire hardware with Mic and Aux input, MIDI and more
NEW: hardware compatible with NI TRAKTOR DJ Studio software
2 virtual decks with zoomable waveforms
Play audio files from time-coded vinyl or CD
Fast search engine works with over 50.000 tracks
High-quality Key Lock (Master Tempo)
NEW: improved time-code readout with absolute/relative modes
NEW: mic recording with instant playback from vinyl
NEW: input recording for capturing your live mix direct to disk
NEW: loop playback makes adding loop samples to the mix easy
NEW: calibration tools provide optimal time-code response tracking
NEW: cue points for marking breaks or other important sections
NEW: intelligent play history with time stamp and printing
NEW: onscreen 1-minute markers for faster visual cueing
Lead-in graphics for use with lead-in grooves on vinyl
Helpful auto gain adjust and BPM detection
Assignable commands using “hot keys” or MIDI control
Compatible with Apple® iTunes™
Plays MP3, WAV, AIFF, AAC, WMA and Audio CD files (DRM-free files only)
Assign the same file to both decks simultaneously
Dual color waveform indicates peaks and density of sound
Track mixing and track organization integrated into one application
Play counter and play time information for each track
De-emphasis modeling for authentic scratching sounds
Time code release function (continues to play at same pitch without time code)
Single controller mode (control both software decks with a single turntable or CD player)
Shows audio CD waveforms in real-time
Mix between FS and analog records or CD's
Play audio CD's from your computer's CD-ROM drive
Play two tracks from one CD simultaneously
Full Drag & Drop capabilities (Mac only)
Supports multiple CD-ROM drives and HD's connected to the computer (Mac only)
System Requirements
Mac:
Minimum: Mac OSX (10.3.3 or higher), G4 533MHz, 256 MB RAM
Recommended: Mac OSX (10.3.3 or higher), G4 1GHz, 512 MB RAM
PC:
Minimum: Windows XP, Pentium III/Athlon 1GHz, 256 MB RAM
Recommended: Windows XP, Pentium IV/Athlon XP 2 GHz, 512 MB RAM
In the Box
Scratch Amp 2
Install disc for TFS 2
4 RCA cables
1 Firewire Cable
3 FS2 Timecode Records
DJ.TStandaard Lid
Sinds: 20-8-2003
Laatste: 21-12-2024
15-9-2004 18:27
Voor de mensen met FS1 schijnt er een inruil programma te komen.
Erg goede actie lijkt mij, dat scheelt de FS verslaafden toch een leuk geldbedragje.
Darth Crossfader
QuincManStandaard Lid
Sinds: 1-8-2003
Laatste: 15-5-2010
15-9-2004 19:00
Hopen dat je nu wel concordes kan gebruiken..
Lollig: vinyl+cd in 1 package!
D@VE!Standaard Lid
Sinds: 16-2-2003
Laatste: 29-9-2010
15-9-2004 21:06
Ik ben zeer benieuwd maar ook naar de prijs ervan... maar wil het zeker testen als het er is zeker ivm met die diercte FireWire aansluiteing op de AMP ideaal voor DJ's alleen nog je iPod meenemen :P
Music Is My Religion !
DJ.TStandaard Lid
Sinds: 20-8-2003
Laatste: 21-12-2024
15-9-2004 22:32
Prijs stond er al, 800 dollar.
Europa wordt vast vierkant genaait dus ik schat dat de prijs op 950 euro komt te liggen.
Darth Crossfader
BerizStandaard Lid
Sinds: 16-9-2004
Laatste: 10-11-2005
16-9-2004 11:59
"inruil programma"??? nog niks van gelezen
zou wel kewl zijn!!!
DJ.TStandaard Lid
Sinds: 20-8-2003
Laatste: 21-12-2024
16-9-2004 16:47
''Trade in program details coming soon''
wink ;)
Darth Crossfader
BerizStandaard Lid
Sinds: 16-9-2004
Laatste: 10-11-2005
16-9-2004 17:09
ok idd,
compleet overgekeken :)
Tribal ChefStandaard Lid
Sinds: 18-11-2003
Laatste: 28-9-2009
16-9-2004 18:46
Jammer weer geen 3 decks sad :(
Sinds: 1-8-2003
Laatste: 15-5-2010
18-9-2004 13:12
www.gearjunkies.com/product_info.php?products_id=13169
