Het profiel van Dj Ponk
Laatste 4 bijdrage(n) van Dj Ponk (Pagina: 1 van 1)
Topic: Reloop RMP1 en RMP 2 (19-1-2007 17:48:00)
RMP-2 black
The Reloop RMP-2 is the premium player in the new compact professional class. A comprehensive DSP effect
unit with single-button synchronisation is linked intelligently here with the properties of the touch-sensitive jog dial.
The RMP-2 offers a tremendously simple and fast effect modulation which will enthuse any remixer.
With a vast range of pitching functions and vinyl-like precision control the CDJ gets everything he wants and more
from a professional player. And even the look of Reloop’s single drive flagship meets all expectations of a high-end device:
The transparency of the surface layout supported by sensible key control lighting, the high-resolution matrix
VFD display and the quality device create a fabulous impression.
Technical Details
* S/N ratio: 97 dB
* D/A transformer: 8-fold/1 bit
* Dimensions: 320 x 110,5 x 340 mm
* Weight: 4,0 kg
Features
* MP3-compatible single front loader CD player
* DSP effect unit (filter, skid, echo, flanger, rrans, phase, pan, break plus hold) with ratio and time parameters
* Automatic and manual beat counter
* Effect link with BPM counter
* Effect modulation via jog wheel
* Touch-sensitive 2-part jog dial
* High-end scratch simulator with return-to-cue function
* 4 independent 5-second sample banks (pitchable)
* 4 independent cue point banks
* ID3-TAG support & CD text
* Track and folder search
* Extra-bright dot matrix VFD display for all functions
* Extra-long pitch fader (on/off option)
* Pitch range +/- 4/8/16/100% (with pitch lock and master speed)
* Pitch bend up to +/- 100%
* Auto cue
* Seamless loop function / re-loop function
* Frame search
* Instant start via 1-bit technology (8-fold)
* Playing address
* 10-second anti-shock memory
* Elapsed/remain time display
* Sleep switch
* Slot-in loading mechanism with light display
* Instant playback as of cue point
* Relay play
* Fader start play
* Digital output
* Headphones OUTTopic: Reloop RMP1 en RMP 2 (14-1-2007 10:18:00)
Maar, hoe zit het dan met Synq?
Brengen dan ook 'n nieuwe cd-speler uit;, of niet?
Topic: Wie is jouw favoriete DJ? (14-1-2007 12:11:00)Brengen dan ook 'n nieuwe cd-speler uit;, of niet?
Axwell !
Topic: Reloop RMP1 en RMP 2 (14-1-2007 10:20:00)
RMP-2 black
Technical Details
* S/N ratio: 97 dB
* Weight: 4,0 kg
Features
* Auto cue
* Frame search
* Playing address
* Sleep switch
* Relay play
* Fader start play
* Digital output
* Headphones OUT
Ze staan nu ook [ al een tijdje ] op site van Reloop:
https://www.reloopdj.com/index.php?id=reloop-cd-player&type=2
RMP-1 black:
Reloop’s RMP line sets a new standard for MP3-compatible CD players: The compact professional class.
This device offers all important functions in one convenient format – the design focuses on the main control elements,
the 20 cm-large jog dial with its touch-sensitive plate and turntable-sized pitch fader.
This concept is geared entirely towards intuitive use and is complemented by the high-resolution
dot matrix multi-colour display. The technical highlight of the Reloop RMP-1 is the sophisticated
scratch function with return-to-cue utility which simply sounds great.
Technical Details
* S/N ratio: 97 dB
* Weight: 4,0 kg
Features
* Extra bright dot matrix VFD display for all functions
* Extra long pitch fader (on/off option)
* Pitch range +/- 4/8/16/100% (with master speed)
* Auto cue
* Frame search
* Instant start with 1-bit technology (8-fold)
* Playing address
* 10 seconds anti-shock memory
* Sleep switch
* Instant playback from cue point
* Relay play
* Fader start play
* Digital output
* Headphones output with volume control
RMP-1 black:
Technical Details
* S/N ratio: 97 dB
* Weight: 4,0 kg
Features
* Auto cue
* Frame search
* Playing address
* Sleep switch
* Relay play
* Fader start play
* Digital output
