Het profiel van Mounier
Laatste 2 bijdrage(n) van Mounier (Pagina: 1 van 1)
Topic: Speaker (23-12-2003 00:25:00)
Hello !
Sorry if I cannot speak Dutch !
Your website appeared on my computer as I was searching for Philips loudspeaker components… It also appears that we have in common a taste for vintage radios (and computers, as far as I'm concerned).
I have a pair of Philips "MFB Electronic 22 RH 532" speakers, housing built-in amplifiers - a free gift from my in-laws, who bought them 30 years ago...
The tweeters & mediums are dead. Philips does not seem to be able to replace them. I just called Philips France, to learn that they no longer make loudspeakers...
Do you know whether these tweeters & mediums are still available ; or, more probably, what are equivalent models can be used as replacements?
References :
• tweeters 2,5 cm AD 0160T
• mediums 12 cm , AD 5060 Sq
(output 20 watts)
What would you recommend ?
Thanks !
Eric Mounier
Topic: Speaker (19-12-2003 16:09:00)
Hello,
Sorry, I cannot speak Dutch.
The tweeters & médiums are dead. Philips does not seem to be able to replace them. I just called Philips France, to learn that they no longer make loudspeakers...
Does anyone know whether these tweeters & médiums are still available ; or, more probably, what are equivalent models can be used as replacements?
References :
• médiums 12 cm , AD 5060 Sq
(output 20 watts)
Thanks !
AD 0160 T4 (ik denk dat je deze hebt)
P: 20 watt max vanaf 1500 Hz (40 watt max vanaf 4000 Hz)
Fr: 1000 hz
bereik: 22.000 Hz
Z: Ohm
AD betekend dat het een universeel voormaat betreft.
eerste 2 cijfers geen de diameter aan, dus 8" voor de woofer en 1" voor de tweeter.
derde en vierde geven het soort magneet aan.
W staat voor woofer en T voor tweeter.
laaste getal is de impedantie, hier dus 4 Ohm.
staat een kast beschreven voor deze woofer van 15 dm3.
BxHxD = 255 X 400 X 180 mm (buitenmaten) gesloten behuizing, houtdikte 10mm
frequentie karakteristiek is erg mooi vlak en gaat van 50 tot 22.000 Hz
verder geen info
