Het profiel van M|A Audiotechniek
Laatste 200 bijdrage(n) van M|A Audiotechniek (Pagina: 4 van 10)
Topic: Nieuwe lab gruppen versterkers (4-5-2007 14:56:00)Is dat hetzelfde, zoals Dré het hier uitlegt? /?i=59Topic: Forum Meeting deel 2 (20-4-2007 18:07:00)Klakkeloos? Site is op de achtergrond kleur en de groote van het venster geheel niet indentiek. Er zit verschil in schaduw, ik zie geen overeenkomende plaatjes, lettertype is anders... Dat noem ik niet een website klakkeloos overnemen.Topic: DMX Studio Professional (15-2-2007 17:04:00)de eurolite TS-7b is ook hetzelfdeTopic: 'Windows Fundamentals for Legacy PCs' (Eiger) als audiomixer/analyzer. (28-1-2007 19:27:00)
Hello, Tom –
One of the drives to development of the fP series after the LAB4000 series was to make changes necessary to gain ETL approval. That was mostly paper work, but it did require the replacement of certain components. At the same time it was a good opportunity to upgrade the amp to the latest released components in the market.
Technically, the biggest change compared to the LAB4000 was our decision to phase reverse ch. B, both input and output. By doing so the amp can draw from both the + and – side on the power supply at the same time, giving 10% more efficiency, and resulting in a better performing amp in the low end and below 4 ohm.
Even though the fP6400 is slightly more powerful we have a lot of customers that are driving the fP6400 and the LAB4000 together. That is how small the differences are between these two ranges.
Please let me know if there are any further questions and thanks for your support of Lab.gruppen products!
Jammer, 10 juni familiedag, 17 juni jarig, en 24 juni Parkpop, dus ik ben niet van de partij
Topic: DMX4ALL Interface (7-4-2007 14:31:00)
start dan dat software programma eens op wat bij die driver zat, en kijk of dat programma je hardware al kan vinden.
Topic: DMX4ALL Interface (7-4-2007 13:15:00)Ik neem aan gewoon instaleren, en dan je usb dmx dongle in je computer steken, en als het goed is zou hij hem dan moeten herkennen.
EDIT
Ik zie dat er geen setup bij zit in de zip. Je moet zoiezo eerst de zip file unzippen. Dan zou je dus gewoon je Dongle in je computer moeten steken, en als hij vraagt naar een bepaalde driver, dan moet je de map selecteren die je hebt ge-unzipped. Dat zou moeten werken.
Topic: DMX4ALL Interface (7-4-2007 11:01:00)Topic: DMX Studio Professional (6-4-2007 10:02:00)EDIT
Deze werkt wel https://www.dmxstudio.eu
Topic: Trafo (10-3-2007 13:26:00)Hoort dit topic niet thuis bij geluid?
Topic: led tubes bevestigen (5-3-2007 06:55:00)Of in de shop zoeken. Ik neem aan dat je deze bedoeld?
Topic: Tv programma vanavond 21.25 (2-3-2007 22:12:00)Beetje laat om nu met ideeen te komen. Ik denk dat we het erover eens zijn dat dit setje geen 15000 euro kost, en ik kan me dan ook niet voorstellen dat de beste man dit ervoor betaald heeft. Het getal 15000 euro zal wel een hoog 'TV-gehalte' hebben.
Topic: Tv programma vanavond 21.25 (1-3-2007 22:12:00)Neeeh, helemaal gemist dit topic... Nu kan ik alleen het einde zien. Zal deze uitzending op https://www.uitzendinggemist.nl komen?
Topic: Andere webshop gebruikt letterlijk tekst new-line! (21-2-2007 21:55:00)GoeieGast schreef:
Das natuurlijk BULLSHIT. Het is voor elke randdebiel duidelijk dat één van de twee websites klakkeloos is overgenomen.Site ziet er erg goed uit, ben zeer benieuwd naar de software. Is er al een defenitieve lijst van alle soorten tafels die de software gaat simuleren?
Topic: Showtec Club Fazer (12-2-2007 16:18:00)Ik zal het aankaarten. Ben dan wel benieuwd hoe een hazer werkt?
Topic: Showtec Club Fazer (12-2-2007 15:38:00)Apparaat is allang over zijn garantie periode heen. Waarom toch doen als er in de handleiding staat dat het niet moet? Omdat het altijd al is gedaan, en het ook altijd al heeft gewerkt. Dan ga ik niet twijfelen of het wel goed is die vloeistof. Die rookmachine is niet mijn ding, ik vul hem bij als het moet, veder is dat niet mijn zaak. Alleen als ik weet dat we de rookmachine ermee slopen, kan ik zeggen dat ze er andere vloeistof voor moeten kopen. Maar als niemand weet wat de gevolgen zijn, dan komen we daar snel genoeg achter, want we hebben 20 liter haze extra in de vooraad.
Topic: Showtec Club Fazer (12-2-2007 15:29:00)In de handleiding staat Do not use liquids designed only for Hazer machines. Oke, maar er staat veder niet bij wat de gevolgen zijn. Onze z300 doet het namelijk wel gewoon met haze vloeistof.
Topic: Showtec Club Fazer (12-2-2007 14:42:00)Ojee, wij voeren onze Z300 van Antari altijd met dit spul. Is dit schadelijk voor je machine?
Topic: (kracht) 16A CEE-contact 25A afzekeren (7-2-2007 06:49:00)''Het geluid is blijft altijd volledig intact.''
Rare zin
Topic: freestyler hulp (2-2-2007 20:38:00)Rare zin
roytie schreef:
ik heb thuis 2 aztek 250 scans hangen weet iemand wat een zelfde is maar van een ander merk?Probleem inmiddels opgelost, mijn windows 2000 cd was gewoon onleesbaar. Speciale dank aan Fossalta
Topic: 'Windows Fundamentals for Legacy PCs' (Eiger) als audiomixer/analyzer. (27-1-2007 17:58:00)
Heb ik gedaan, en hij start nu ook gewoon de instalatie via de cdrom, maar vreemd genoeg blijft hij vragen of ik de Cd in drive A wil doen (gek, want drive A is diskette).
Mischien iemand een idee hoe ik lightjockey 2.5 wel kan laten werken op WinFLP? Ik krijg steeds als ik de instalatie start de melding: Geen geldige win32 toepassing.
